09-28-2007, 15:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: romania brasov Age: 46
Member: 19672 Status: Offline Sonork: 100.65069 Thanks Meter: 46 | daulle sim pinout? |
09-28-2007, 15:41 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
02-24-2008, 09:50 | #3 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | i used infi rx tx finder and it said: RX=12 and TX=10 but after i made the cable it showed boot error even i dont press the power key. Is this the correct pinout, anyone? if there is a succesfull pinout could anyone share? br, s1emens |
02-25-2008, 19:33 | #5 (permalink) | |
Member: 40602 Status: Offline Thanks Meter: 118 | Quote:
any suggestion? br, s1emens | |
02-25-2008, 21:26 | #7 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | ok i'm done with this phone, tried probably 50 times but still not working. just curious, is it possible to make infi rx tx finder as an adapter to communicate with phones and we dont have to make cable again, i mean by setting the rx tx pin electronically and we can use in chinese miracle module option to connect to phone via infi rx tx finder box? br, s1emens |
02-25-2008, 22:12 | #8 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | @all thanks finally with a little tricks by connecting GND to cable it works. hhahahahaaahhaaaa @infinityhelp maybe u need to add gnd pin beside rx and tx. although gnd can easily measured but it really help.thanks br, s1emens |
02-26-2008, 00:17 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! so your problem was that you used battery after you found pinout? because if you keep phone untouched after pinfinder found phone- it for sure will communicate with CM soft or any other soft |
03-04-2008, 04:20 | #10 (permalink) | |
br, s1emens | |
chinese nokia n99i dual sim pinout here | sudeeshveekey | Infinity-Box | 6 | 12-11-2007 14:46 |
Nokia N9s Dual-sim PINOUT | AKKA | Chinese Cocktail | 5 | 12-08-2007 11:55 |
CECT F22 DUAL SIM pinouts for 1st and 2nd CPU | ezzis | Infinity-Box | 2 | 12-06-2007 04:09 |
n95 bluetooth 2x6 single sim pinout not work need pinout | walid1751 | Infinity-Box | 4 | 11-13-2007 15:40 |
n95 cineese dual sim pinout? | .:R-mitik:. | Infinity-Box | 3 | 10-03-2007 07:21 |
