Old 09-10-2008, 15:34   #1 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
sigmatel s4 & iphone
hello infinity
sigmatel s4 and iphone read full flash eeprom ok, complete ffs format ok , but no power on , I flash mobiles and repair secruity area no use. any solution please........
Old 09-10-2008, 16:33   #2 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
sir please check logs:
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_ET FIHAP_V026.BIN
ver. sw2: S4_TOSHIBA_ETFIHAP_V026, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 56 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 09-10-2008, 20:35   #3 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
dear do complete format with charged battery after done press power botton for one minute or resold flash IC will b 100% on good luck
Old 09-10-2008, 23:59   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@kiran
If phone can not power-on after flash+format you have a reason to check phone hardware.
Flight Mode to Dual Sim Mode in Sigmatel S4? priyoghosh Chinese Models & Cloned Phones 82 09-16-2013 12:23
Camera and video recoder problem in SIGMATEL S4 chinees Mobile sandipdas365 Chinese Models & Cloned Phones 4 06-20-2009 09:58
Sigmatel S4 xpsunny Infinity-Box 10 08-21-2008 22:25
How to use Net through Sigmatel S4 ? misrmp Chinese Models & Cloned Phones 1 08-20-2008 08:13
Sigmatel S4 xpsunny Chinese Models & Cloned Phones 2 08-18-2008 10:46
Page generated in 0.15267 seconds with 10 queries
