Db2020 Call Fail After Unlock Dear Infinity team. I have unlocked a couple K800 and W850 units successfully via davinci team. However on 2 of these units after i unlocked them i was able to make calls on 1900 but not 900 Mhz networks. I tried flashing debranding etc with both davinci and cruiser but with no success. I had to pay for flashing and thats a waste for nothing. Can you tell me if your flash will unlock or allow me to use the european frequencies. I had the problem with Vodafone and 3 network. Thanks in advance. I know this because here we have both US and European networks. |
Hi , we can not promise you if your phone will be repaired or not , try to find the firmware version that was existing before you unlocked and flash it back to the same , check manually band selection in network settings |
Ok this is not a band selection problem or a problem that any user settings change can solve. It is a method of locking the phones so that the can't be used in another region. I had discussed it with the davinci team and they told me that the problem is in the GDFS area. Can you flash that region of the phone? |
If you write GDFS fully from other phone then u can put RIP on it after. Br;) |
full flash ur fone with settol only one credit ..all will be well |
i dont think this solution can sort out the problem bro. :) |
do previously it was working with 900mhz than there is no use to unlock and use. |
