Old 04-22-2007, 22:27   #1 (permalink)
Member: 160245
Thanks Meter: 19
Db2020 Call Fail After Unlock
Dear Infinity team. I have unlocked a couple K800 and W850 units successfully via davinci team. However on 2 of these units after i unlocked them i was able to make calls on 1900 but not 900 Mhz networks. I tried flashing debranding etc with both davinci and cruiser but with no success. I had to pay for flashing and thats a waste for nothing. Can you tell me if your flash will unlock or allow me to use the european frequencies. I had the problem with Vodafone and 3 network. Thanks in advance. I know this because here we have both US and European networks.
Old 04-22-2007, 23:14   #2 (permalink)
Member: 128745
Thanks Meter: 16,871
Hi ,
we can not promise you if your phone will be repaired or not ,
try to find the firmware version that was existing before you unlocked
and flash it back to the same , check manually band selection in network settings
Old 04-23-2007, 01:12   #3 (permalink)
Member: 160245
Thanks Meter: 19
Ok this is not a band selection problem or a problem that any user settings change can solve. It is a method of locking the phones so that the can't be used in another region. I had discussed it with the davinci team and they told me that the problem is in the GDFS area. Can you flash that region of the phone?
Old 04-23-2007, 01:28   #4 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 56,131
If you write GDFS fully from other phone then u can put RIP on it after.
Old 04-23-2007, 22:29   #5 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
full flash ur fone with settol only one credit ..all will be well
Old 04-24-2007, 18:28   #6 (permalink)
Member: 160245
Thanks Meter: 19
Yes i suspected that. Thats why we need to flash only the relevant part of the GDFS. If this is not possible then the phone really can't be unlocked for use on our 900Mhz network.
Old 05-29-2007, 19:49   #7 (permalink)
zenadia's Avatar
Member: 315127
Thanks Meter: 6
i dont think this solution can sort out the problem bro.
Old 05-31-2007, 18:39   #8 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,847
do previously it was working with 900mhz than there is no use to unlock and use.
z240 call failed after unlock rajufzr NSPRO 4 10-05-2009 12:59
Call failed after esn change celutek Universalbox 3 03-07-2007 00:56
my501x call fail after unlock gorgans SAGEM JTAG UNLOCKER 5 01-10-2007 16:15
v975 call failed after unlock noone0 Smart-Clip 17 08-30-2006 12:05
c550 call failed after unlock DarkSkir Motorola P2k 2 04-01-2005 16:56
Page generated in 0.36708 seconds with 8 queries
