02-07-2008, 13:24
#1 (permalink)
Member: 332978
Thanks Meter: 59 | dbest 2 imei problem mode-1 Quote:
Action: imei
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: 100_HW
Software version: 1.00"
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 350***********
imei write method: mode-1
new imei: 350************
imei verified Ok
Finished, time used: 36 sec
Power off phone now !
| mode2 Quote:
COM25 [VCP0] selected
Action: imei
imei write method: mode-2
19200
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:8D89633
Connecting, wait...
Release Power button now !
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: 1.00
Version: 100_HW
detecting structure #2...
0
done
42 byte(s) read
imei: 350********
connection Ok
detecting structure #2... 0
done
42 byte(s) read
verification...
verification done: 3504*******
Finished, time used: 11 sec
Remove/Install battery now !
| mode-3 Quote:
Device: Autodetect 6205-6227 NOR
Action: imei
imei write method: mode-3
new imei: 350******
Boot...
baud autodetection active
19200
Connecting, wait...
CPU: MT6226
chip: 0031:8D89633
high speed disabled
boot step size: 0002
Boot Done
Initialize...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: IAC26_PCB01_GPRS_MT6226_S01.1_00.BIN
ver. sw2: 1.00, 00000000
ffs offset/size: 00E00000/001F0000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [eeprom[IAC26_PCB01_GPRS_MT6226_S01.1_00.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[IAC26_PCB01_GPRS_MT6226_S01.1_00.BIN]_20080207-141904.B0E.bin
Identification Done
Manipulation...
8 step(s) required to finalize
Manipulation Done
Finalization...
Finalization Done
Write...
Write: eeprom
Write Done
Finished, time used: 163 sec
| imei 1 change ok put imei 2 not change vhy?....
cpu1 rx-tx = cpu 2 rx-tx ? |
