01-14-2008, 14:30 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | DBEST VT888 (VT880c) PINOUT! today I got one phone called DBEST VT888GSMH. I opended the phone and there is als one more label and on this label written as VT 880c. The phone is located here.. you can look.. http://www.made-in-china.com/showroo...ST-VT888-.html Phone has MT6226BA CPU and double simmed. I urgent need its PIN OUTs. Please.. if any body has about this phone any info please urgent we need its pin outs.. it has a samsung D500 18 pin connector.. regards.. |
01-14-2008, 19:11 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i did little search on forum and i can say following: Very rare model. worth to start searching its pinout by yourself. start from opening phone and looking for marked test points on PCB. if no success- you must turn to 18pin connector. I would advice pin voltage measuring method described here: http:///vbb/attach...7&d=1187384324 |
01-23-2008, 20:57 | #4 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | please for that phone.. I have found Rx1 and TX1 using Santehnik_Tj method but can not find RX2 TX2 or maybe something wrong.. keybord 1 IIIIIIIIIIIIIIIIII 18 1+2 -> VCHARGE 17+18 -> GND 7 -> RX1 8 -> TX1 I could Read info and first IMEI by these RX1 and TX1, and there is a very poor voltage on (0.5v)15 and (0.9v)16 but I tried to read seccond IMEI always fail..How to read/change seccond IMEI? maybe these Rx2 and Tx2 is incorect or maybe something else is wrong.. Please urgent Help.. I am in trouble.. regards.. |
01-23-2008, 22:23 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think wrong pinout for second CPU. i would advice to check pins 5,6 or 9,10 usually they put data pins near, but... hell knows those chinese programmers... |
01-24-2008, 10:20 | #6 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | can you tell me pls? if I find corect pins when read info what I will get? the same as Rx1,Tx1 or what? and one more both IMEI are edited/readed differently, not at same time? one by one? For Ex. first we will connect Rx1-Tx1 to the box rx-tx than after finish the first step we will connect Rx2-Tx2 to the same RX-TX of the box, is that right?or maybe something else? what is the precedure? regards. |
01-24-2008, 17:25 | #8 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | Now I got one more phone with 2 CPU. it is General Mobile DTS11. I found out both RX1,TX1 and RX2,TX2. I can read and change IMEI1 but infinity can not read or change IMEI2. but when make "Read Detailed Infiormation" software works and read all. this mean Rx2,TX2 is corect and working but infinity box can not read normal information from seccond CPU or maybe flash. it is also like KE970, when phone is on it does not read anything but when in boot mode it can read write data.. infinity team, could you please tell me now what to do? how to change seccond IMEI with infinity!? here is a log of detailed information for seccond CPU of DTS11: COM4 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF detecting ffs structure pass 1... ...... detect standard fat location pass #1... ........... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ...... detect standard fat location pass #1... ...... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Finished, time used: 44 sec Remove/Install battery now ! |
i want E66 UFC pinout | abdurrahimsagar | Nokia Hardware & Hardware Repair | 2 | 05-27-2010 20:37 |
Pinouts for Wi-Fi Mobile C5000 | Stoyan | Infinity-Box | 3 | 04-01-2010 06:06 |
CD player pinout 1J0 035 119c | attilaa0 | CAR Electronics | 4 | 03-30-2010 07:16 |
dbest 2 imei problem | sancakaziz | Infinity-Box | 3 | 02-08-2008 00:02 |
S100/105.Pinouts.I don't quite understand pinout from S105 scheme. | DoctorV | Trident/AGERE Platform | 9 | 04-03-2003 07:14 |
