12-08-2008, 11:34 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | Dead after complet formet .... !! COM10 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:CB76:6D8A high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.7C846847.[T900_B911_PCB01_GPRS_MT6226_S01.IC1289_SUM_BT_PAS6 311_1_1.BIN_B527CAF6].rpl ==================== New firmware detected: T900_B911_PCB01_GPRS_MT6226_S01.IC1289_SUM_BT_PAS6 311_1_1.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 7C846847 identification#1 protocol ver: 04 ver. sw1: T900_B911_PCB01_GPRS_MT6226_S01.IC1289_SUM_BT_PAS6 311_1_1.BIN ver. sw2: T900_B911.IC1289_SUM_BT_PAS6311_1.1, 0935D84A ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_7C846847_T900_B911_PCB01_GPRS_MT6226_S01 .IC1289_SUM_BT_PAS6311_1_1.BIN_B527CAF6_20081206-142428.B0X.bin Finished, time used: 127 sec Remove/Install battery now ! DEAD AFTER COMPLET FORMET HAVE SOME BACK UP #1 LIKE ....Files\InfinityBox\ChineseMiracle\backup_securi ty\id.7C846847.[T900_B911_PCB01_GPRS_MT6226_S01.IC1289_SUM_BT_PAS6 311_1_1.BIN_B527CAF6].rpl # 2 D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_7C846847_T900_B911_PCB01_GPRS_MT6226_S01 .IC1289_SUM_BT_PAS6311_1_1.BIN_B527CAF6_20081206-142428.B0X.bin HOW CAN RESTOR BACK UP BR.DYNET |
12-08-2008, 13:18 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can restore full backup only if you have made it before format. Do you have original full flash backup file ? Read text in log very carefully ! |
12-08-2008, 13:46 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Rajasthan (Kota)
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | if u dont have back up of flash file then go to chinese miracle folder and see the logs u will see the flash file after that find the flash file in infinity support aread |
12-08-2008, 16:08 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If this file can not be found in support area it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. |
S3500 dead after complete flash | imran_bcz | UST Pro II | 0 | 08-08-2009 16:17 |
q380 dead after complete flash still dead | bhoybits99 | PadFinder box | 1 | 12-21-2008 11:45 |
J600v Dead After Complete Flash !! | Software Centre | UST Pro II | 12 | 07-28-2008 08:48 |
k750i Dead After Complet flash ! | ti_zana | Cruiser Suite | 8 | 01-05-2007 21:20 |
C139.....still Dead After Complete Flashing. | albarka network | Infinity-Box | 14 | 09-11-2006 19:18 |
