03-13-2009, 04:14 | #1 (permalink) |
Registered User Join Date: May 2007 Location: india
Member: 511520 Status: Offline Sonork: 100.1573642 Thanks Meter: 127 | dead china mobile via format i receieve i china mobile with restart problem with sim i did format to it but after complet format it dead i try many time format but it still dead i search its flash file in supoort area but not found in support now i read fullflash from dead mobile its model name is zt998 help me |
03-13-2009, 08:37 | #4 (permalink) |
Member: 511520 Status: Offline Sonork: 100.1573642 Thanks Meter: 127 | ==== log opened: [3/12/2009 3:42:16 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.77 S/N: 0B7C:0112 Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [3/12/2009 3:42:26 PM] ==== COM3 [VCP0] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:FC03:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.77, database date: 25.02.2009): PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN ver. sw 2: T228DY.GKX.0.3, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN]_20090312-154446.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 140 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to dhawan_boss007 For This Useful Post: |
03-13-2009, 08:40 | #5 (permalink) |
Member: 511520 Status: Offline Sonork: 100.1573642 Thanks Meter: 127 | ==== log: [3/12/2009 3:49:48 PM] ==== COM3 [VCP0] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:FC03:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.77, database date: 25.02.2009): PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN ver. sw 2: T228DY.GKX.0.3, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_GKX_0_ 3.BIN]_20090312-160113.B0M.bin Finished, time used: 772 sec Remove/Install battery now ! smart-card disconnected |
china mobile flashing formatting | ajit bs | Infinity-Box | 1 | 03-28-2010 17:04 |
china mobile flashing formatting | ajit bs | Chinese Models & Cloned Phones | 0 | 03-28-2010 16:54 |
CHINA MOBILE VEDIO FORMAT .moa Convert Soft | gopalhot | Chinese Models & Cloned Phones | 0 | 06-19-2008 18:13 |
How I Servive My Dead China Mobile | dil_PAKISTANI | Infinity-Box | 3 | 01-24-2008 16:08 |
