dead by formatting i have china alfatel h1 phone working fine i complete format phone phone dead i flash with new flash file phone still dead log is hear board id huscky-v7.0 LOG COM9 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O__Alfatel-H1A_16m_En_Ru_Fr_Hi.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O__ffs_01.B0E. bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6603:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D124BE46.[HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O.BIN_CABEE31B].rpl rom info detection finished device-id: D124BE46 rom info ver: 04 sw version: HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O.BIN project-id: PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O, 1BE3BECA code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H USCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O__system_log_ D124BE46_CABEE31B_20110521-105457.B0X.bin Area: Firmware flash: EC240200000000:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: EC240200000000:18E59F00000000 Write: Eeprom/ffs usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H USCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O__system_log_ D124BE46_CABEE31B_20110521-111445.B0X.bin Finished, time used: 21 min 28 sec Remove/Install battery now ! |
re write the file your problem will bee 100 sure |
hello! which was phone's original software version? you can find it in operation.log file. open it with notepad and scroll it up from the end. search for first format operation. there you will see original software version. Compare it will flash file you used for flashing. Please remember that difference even 1 digit can cause dead phone |
pls check your flash file and match original back up file if any difference btw original backup and your new flash file then phone cant power on need same file with original backup |
