03-31-2008, 11:00 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: HEAVEN
Member: 285345 Status: Offline Thanks Meter: 324 | dead LG kg 130 when I connect and check its show like 1st boot ok . but I dont know how to revive it and how to select files.There r 4 files . firmware file system Alchemy data Eeprom should I select all these files at same time O r should select 1 file and write then write 2nd and write and then 3rd and then 4th.?????????? |
03-31-2008, 14:14 | #3 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | COM4 [VCP0] selected Device: LG KG130 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 355311013735768 current otp imei: 355311013735768 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35531101373576 8_LG KG130_20080331-173506.B1E.bin ....... version: ***-XXV10a07KG130P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area error: no any expected answer error: flash write error: 18194000:00002000 error: error# 000000FF error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 error: no any expected answer error: flash write error: 18194000:00002000 Write Fail Finished, time used: 2326 sec Remove/Install battery now ! |
03-31-2008, 14:32 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It looks like phone hardware is damaged (damaged or bad soldered flash chip). Charge battery completely, repeat flash process again. If still no luck reball flash chip. |
Unlock LG KG 130?? | Mapamann | HWK | 22 | 04-22-2008 14:46 |
LG Kg 130 unlock ? reset? | alunecosu_hd | PolarBox 3 | 0 | 12-17-2007 10:21 |
successfully flash lg kg 130 | talatmehmood | Multi-Box | 1 | 12-17-2007 10:12 |
Lg Kg 130 | sakka | PolarBox 3 | 3 | 06-15-2007 22:23 |
Unlock Off Lg Kg 130 | pietpiraat | LG | 1 | 05-29-2007 00:27 |
