04-01-2015, 08:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | dead MT6583 I have a dead MT6583. Operation : Check / Read Info [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : FA5D679DFFF4DD5F0F800A2012940000 DA Stat : v3.2 on BBID : 0x86 Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Depending on the version of SP FLASH TOOL I have the following errors: S DA SDMMC WRITE FAILED 3149 S STORAGE NOT MATCH 3167 |
04-01-2015, 09:19 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, By your log seems as hardware fault, but cannot be sure as depends on lot of other things also. FlashInit not supported for MT6583|6589 yet, but will follow soon. Br. |
04-01-2015, 09:40 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Code: eMMC_ID : FA5D679DFFF4DD5F0F800A2012940000 Planning add in some of next versions ( maybe 1.20 or so ) "Extended HW Logging" - which will help determine storage problems. |
