dead Tecno W3 hello guys , i have dead phone (tecno W3 ) with MT6580 when i try Identify option in CM2MTK Just get this result Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454838434538010AC8628CB353 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! Do I need to flash the phone with Stock Rom i can`t do READ FULL flash in CM2MTK any help please |
i try to flash the phone with this firmware MT6580_TECNO-W3_6.0_TECNO_W3-H806A1-M-161031V90 Just i am get this result Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454838434538010AC8628CB353 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:25 Reconnect Power/Cable! any help |
U can flash by sptool format+download. Battery charged |
I tried with SP flash tool only get this message BROM ERROR : s_ft_enable_Dram_fail (4032) [emi] enable dram failed! [hint] Please check your load matches to the target which is to be downloade |
to correct this you need the exact rom for your device,, first check the build number of your w3 and the build number of,the rom you,are flashing am sure they wont match so download the exact rom with the same build number as your w3 |
Hello guys I flashed another preloader (bootloader) and the device got dead, after hours of working I was able to revive the device again as listed bellow: The device has internal name as (W3-H806A1) or (W3-H806B1) you have to choose the proper build for your device. Then you have to choose the correct bootloader of your device here is the link of all boot-loaders builds: https://mega.nz/#F!TZBimKJD!3sYbVVL57KdtIjjYZf5ywA Please match the Flash ID supported by bootloader and use this SP Flash Tool 5.1628 Try to hold Volume Up or Volume Down while connecting USB cable during flash operation... Try and feed me back Thanks |
Please I need file to revive my dead tecno wx3 |
Hello I got the same issue here, Tecno W3 completely dead.. Miracle box shows BootData Error(1) 1366 FD4_O. Yes am trying all your suggestions to fix the problem, you will know... |
Hi, today i have got the phone Tecno W3 from my customer to flash it but when i tried to flash it with Miracle Thunder it readed by the tool and everything showed successful means that the phone is flashed successful but when i turned on the phone, there is nothing changed, all problems, passwords, custom wallpapers and others remains there. What does cause the phone to be unflashable? |
With CM2 u just need to read EMMC TEST. Meanwhile your phone emmc is faulty... |
flash only preloader your phone preeloader not active |
dont waste time this is a emmc chip problem try to make reballing if not working then change emmc chip u will b done |
