Old 12-02-2017, 18:24   #1 (permalink)
Member: 2493870
Thanks Meter: 9
dead Tecno W3
hello guys , i have dead phone (tecno W3 ) with MT6580
when i try Identify option in CM2MTK Just get this result
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 700100454838434538010AC8628CB353
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:24
Reconnect Power/Cable!
Do I need to flash the phone with Stock Rom
i can`t do READ FULL flash in CM2MTK
any help please
The Following User Says Thank You to muddather For This Useful Post:
Old 12-02-2017, 22:56   #2 (permalink)
Member: 2493870
Thanks Meter: 9
i try to flash the phone with this firmware
MT6580_TECNO-W3_6.0_TECNO_W3-H806A1-M-161031V90
Just i am get this result
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0xC40B0000
EMICFG_RET_FAILED
CodeDefine : DA_DEVICE_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:25
any help
Old 12-03-2017, 03:39   #3 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 393
U can flash by sptool format+download. Battery charged
The Following 3 Users Say Thank You to elpring For This Useful Post:
Old 12-03-2017, 11:25   #4 (permalink)
Member: 2493870
Thanks Meter: 9
I tried with SP flash tool
only get this message
BROM ERROR : s_ft_enable_Dram_fail (4032)
[emi] enable dram failed!
[hint]
Please check your load matches to the target which is to be downloade
Old 01-30-2018, 07:49   #5 (permalink)
Member: 2751731
[hint]
to correct this you need the exact rom for your device,,
first check the build number of your w3 and the build number of,the rom you,are flashing
am sure they wont match so download the exact rom with the same build number as your w3
The Following User Says Thank You to mrbright For This Useful Post:
Old 01-30-2018, 08:57   #6 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,888
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:24
any help please
This as turn to hardware issue, heat emmc and retry
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 10-11-2018, 11:58   #7 (permalink)
Member: 2119579
Thanks Meter: 17
Hello guys
I flashed another preloader (bootloader) and the device got dead, after hours of working I was able to revive the device again as listed bellow:
The device has internal name as (W3-H806A1) or (W3-H806B1) you have to choose the proper build for your device.
Then you have to choose the correct bootloader of your device here is the link of all boot-loaders builds:
https://mega.nz/#F!TZBimKJD!3sYbVVL57KdtIjjYZf5ywA
Please match the Flash ID supported by bootloader
and use this SP Flash Tool 5.1628
Try to hold Volume Up or Volume Down while connecting USB cable during flash operation...
Try and feed me back
Thanks
The Following 2 Users Say Thank You to Leonelle For This Useful Post:
Old 11-18-2018, 22:59   #8 (permalink)
Member: 2746896
Please I need file to revive my dead tecno wx3
The Following User Says Thank You to Murobaba For This Useful Post:
Old 08-16-2019, 13:13   #9 (permalink)
Member: 2911939
Hello I got the same issue here, Tecno W3 completely dead..
Miracle box shows BootData Error(1) 1366 FD4_O.
Yes am trying all your suggestions to fix the problem, you will know...
Old 08-16-2019, 16:00   #10 (permalink)
Member: 1677653
Thanks Meter: 1,888
Where is cm2 operation log?
Page generated in 0.28796 seconds with 7 queries
