Technology@01 | 12-06-2018 23:25 | Dear Jaydi Sir Please Help.. Hello Sir..
i have a phone which is secured one (boot)
when try to connect with normal mode this error Code:
Operation : Identify [ v2.02 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM Port (COM120)
MODE : PRELOADER PORT
PORT : 120
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCC00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00002001 : DA SEND ERROR!
ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable! After using Custom Settings it connects :) :cool: Code:
PORT : 120
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : da_pl.bin
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
eMMC : OK
eMMC : 700100454841434541010579B5344DBD
DAInf: 4 : 2 : 155
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 700100454841434541010579B53444BD
EMMC: VEN : KINGSTON | OEM : 01 | DEV : EHACEA
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A5000000 [ 14.58 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCC00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 19985AE5C305ACC586E6319CCF34035C
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level : NRD90M
Display ID : MMX_Q440_SW_V04_HW_V3.0_20170802
Ver. CodeName : REL
Ver. Release : 7.0
Sec. Patch : 2018-08-05
Build Time : 1535335365
Product Model : Micromax Q440
Product Brand : Micromax
Product Name : Q440
Product Device : Q440
Product Board : Q440
Product Manfct : Micromax
Board Platform : mt6737t
Product Info : Q440
USERDATA : PLAIN ( NOT encrypted )
Done!
Elapsed: 00:00:20 write flash error :confused::confused::confused::confused: Code:
Operation : Write Flash [ v2.02 ]
Repartition : Disabled
Flash Verify : Enabled
Reg.Pre-Erase : Disabled
Verify HW/SW : Disabled
SData Backup : Disabled
Safe UserData : Disabled
Files :11
[FL] : Set : preloader_spro6737t_65_n.bin
[FL] : Set : lk-sign.bin
[FL] : Set : boot-sign.img
[FL] : Set : recovery-sign.img
[FL] : Set : logo-sign.bin
[FL] : Set : secro-sign.img
[FL] : Set : trustzone-sign.bin
[FL] : Set : system-sign.img
[FL] : Set : cache-sign.img
[FL] : Set : userdata-sign.img
[FL] : Total size : 0xEA981554 [ 3.67 GB ]
PORT : 120
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
AGENT : da_pl.bin
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
DA : DRAM ready!
EMMC:
Boot done!
SEC_DL : True (CUST)
SEC_ID : 0x61666337613830363937396132393834
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader code ...
Error : Flashing failed!
Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report!
Reconnect Power/Cable! Read Firmware Error :confused::confused::confused::confused: Code:
Operation : Read Firmware [ v2.02 ]
PORT : 120
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
AGENT : da_pl.bin
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
DA : DRAM ready!
EMMC:
Boot done!
Ver. CodeName : REL
Ver. Release : 7.0
Product Name : Q440
Product Info : Q440
MT6737T__Micromax__Micromax_Q440__7.0__MMX_Q440_SW_V04_HW_V3.0_20170802__NRD90M__Q440
Read : preloader.bin
Read : proinfo.img
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : recovery.img
Read : logo.bin
Error : Failed to read data! Connection or power problem!
Check cable, battery, connection and drivers!
Reconnect Power/Cable! please help i have 4 units with same issue ... |
