Old 12-06-2018, 23:25   #1 (permalink)
Member: 2582286
Thanks Meter: 14
Unhappy Dear Jaydi Sir Please Help..
Hello Sir..
i have a phone which is secured one (boot)
when try to connect with normal mode this error
Operation : Identify [ v2.02 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM Port (COM120)
MODE : PRELOADER PORT
PORT : 120
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCC00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
  BROM  : 0x00002001 : DA SEND ERROR!
  ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
  INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
After using Custom Settings it connects
PORT : 120
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : da_pl.bin
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
eMMC : OK
eMMC : 700100454841434541010579B5344DBD
DAInf: 4 : 2 : 155
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 700100454841434541010579B53444BD
        EMMC: VEN : KINGSTON | OEM : 01 | DEV : EHACEA
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x3A5000000 [ 14.58 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        DRAM: 0x80000000 [ 2.00 GB ]
        CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCC00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 19985AE5C305ACC586E6319CCF34035C
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : NRD90M
Display ID     : MMX_Q440_SW_V04_HW_V3.0_20170802
Ver. CodeName  : REL
Ver. Release   : 7.0
Sec. Patch     : 2018-08-05
Build Time     : 1535335365
Product Model  : Micromax Q440
Product Brand  : Micromax
Product Name   : Q440
Product Device : Q440
Product Board  : Q440
Product Manfct : Micromax
Board Platform : mt6737t
Product Info   : Q440
USERDATA : PLAIN ( NOT encrypted )
Done!
Elapsed: 00:00:20
write flash error
Operation : Write Flash [ v2.02 ]
Repartition   : Disabled
Flash Verify  : Enabled
Reg.Pre-Erase : Disabled
Verify HW/SW  : Disabled
SData Backup  : Disabled
Safe UserData : Disabled
Files :11
[FL] : Set : preloader_spro6737t_65_n.bin
[FL] : Set : lk-sign.bin
[FL] : Set : boot-sign.img
[FL] : Set : recovery-sign.img
[FL] : Set : logo-sign.bin
[FL] : Set : secro-sign.img
[FL] : Set : trustzone-sign.bin
[FL] : Set : system-sign.img
[FL] : Set : cache-sign.img
[FL] : Set : userdata-sign.img
[FL] : Total size : 0xEA981554 [ 3.67 GB ]
PORT : 120
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
AGENT : da_pl.bin
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
     DA : DRAM ready!
        EMMC:
Boot done!
SEC_DL : True (CUST)
SEC_ID : 0x61666337613830363937396132393834
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader code ...
Error : Flashing failed!
Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report!
Read Firmware Error
Operation : Read Firmware [ v2.02 ]
PORT : 120
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
AGENT : da_pl.bin
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
     DA : DRAM ready!
        EMMC:
Boot done!
Ver. CodeName  : REL
Ver. Release   : 7.0
Product Name   : Q440
Product Info   : Q440
MT6737T__Micromax__Micromax_Q440__7.0__MMX_Q440_SW_V04_HW_V3.0_20170802__NRD90M__Q440
Read : preloader.bin
Read : proinfo.img
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : recovery.img
Read : logo.bin
Error : Failed to read data! Connection or power problem!
Check cable, battery, connection and drivers!
please help i have 4 units with same issue ...
Old 12-07-2018, 01:38   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 4,123
What is your database version?
Old 12-07-2018, 05:14   #3 (permalink)
Member: 1477125
Thanks Meter: 79
Bro try with cm2 mtk v 1.58
and what is problem in your phone
Old 12-07-2018, 11:41   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,651
Upload DA and preloader files from this device. Will check it and fix, if need.
Old 12-08-2018, 12:07   #5 (permalink)
Member: 2582286
Thanks Meter: 14
Already Tried Failed ..
Old 12-08-2018, 12:08   #6 (permalink)
Member: 2582286
Thanks Meter: 14
from where i can check that.. ??
Old 12-08-2018, 12:08   #7 (permalink)
Member: 2582286
Thanks Meter: 14
Will PM You the DA And Preloader
Page generated in 0.30104 seconds with 7 queries
