01-11-2017, 08:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | need solution for z14 Scatter Load Ok , BaseBand : MT6755 , Project : gionee6755_66_m , Storage : EMMC Files found : 16 , Set to Flash : 15 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : Z14 Device CPU : MT6755 Device IntName : Z14 Device Version : 6.0 Device Compile : 10/29/2016 5:32:32 AM Device Project : GBL7533QM_0203_T5931 Device ExtInfo : Z14 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42071190D01D83C1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x70D24A4C77D20C3141D0AE385E1720CA INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : gionee6755_66_m , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000001A80000 Erase : 0x0000000001BC8000-0x0000000004000000 Erase : 0x0000000007000000-0x0000000000040000 Erase : 0x0000000007800000-0x0000000002C00000 Erase : 0x000000000A900000-0x000000073C2FBE00 Flash Erase Done, time used : 00:00:03 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Ok Flash Partition : MD1IMG Image Flash Ok Flash Partition : MD1DSP Image Flash Ok Flash Partition : MD1ARM7 Image Flash Ok Flash Partition : MD3IMG Image Flash Ok Flash Partition : LK Image Flash Ok Flash Partition : LK2 Image Flash Ok Flash Partition : BOOT Image Flash Ok Flash Partition : LOGO Image Flash Ok Flash Partition : TEE1 Image Flash Ok Flash Partition : TEE2 Image Flash Ok Flash Partition : SECRO Image Flash Ok Flash Partition : SYSTEM Image Flash Ok Flash Partition : CACHE Image Flash Ok Flash Partition : USERDATA Image Flash Ok Flash Write Done, time used : 00:02:42 Done! Elapsed: 00:03:00 Reconnect Power/Cable! |
