02-17-2017, 15:23 | #3 (permalink) |
Freak Poster Join Date: Dec 2011 Location: rajasthan,india
Member: 1705399 Status: Offline Thanks Meter: 81 | here is log handset info----- device name- panasonic eluga A company- panasonic Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 07E5557C ID_BLOCK_I : 008140E1 ID_BLOCK_L : 17C5C7670F58A9174C1498A5719E4FCA ID_BLOCK_L : 067811E55298E077D40F1858B74448DF Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
06-17-2017, 14:42 | #4 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | is there any solution to read the firmware of eluga a , i have one working set and i want to read the software .. Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Identify [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 049EE152 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 49AF9D396506DF699A3EF2DB07C8619C ID_BLOCK_L : CFA7DE2C8D512BBE0DC8C1937C8DB106 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
06-21-2017, 14:28 | #10 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
Infinity Use Its Own Loaders....For Select Loader From Firmware U Need Rawprogram.xml But Eluga A Having Different File Format N Flash In Fastboot Mode So U Can't Do With CM2 ATM. I Have EDL Flashing File Too But It Also Having Diff Format Not Like Other Phones...It Having 3 XML ... 1st Contain Loader 2nd Contain "Content" 3rd Having Patch If U Select This With CM2 U Get Invalid File Format Or File Damage Error. Soon It Will Be Supported I Will Send Loaders To Team For Add This ASAP. :-) | |
06-22-2017, 13:12 | #12 (permalink) | |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
thanks i am waiting | |
08-02-2017, 20:48 | #14 (permalink) | |
is there any progress to add the loaders of this device with cm2 ? | |
