10-20-2015, 23:33 | #1 (permalink) |
Insane Poster Join Date: May 2015
Member: 2391357 Status: Offline Thanks Meter: 3 | desire 816h imei repair problem i have one set of desire 816h with mtk6592V it have nv problem and invalid imei i can't repair it with 1.34 i select desire816g.... in sp model select it hang after : Reading Initial Info, Wait... |
10-21-2015, 08:58 | #3 (permalink) |
Member: 2391357 Status: Offline Thanks Meter: 3 | Operation : Repair Security [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 83 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50314A39354B1205A5514E12A1 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : K59J1 [eMMC] : FLASH_CID : FE014E50314A39354B1205A5514E12A1 [eMMC] : FLASH_EXT : 00200000/00200000 [eMMC] : FLASH_LEN : 0x00000001D3000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 358353xxxxxx IMEI [01] : 358353xxxxxxx Set IMEI [00] : 35835xxxxxx Set IMEI [01] : 358353xxxxxx Prepare finished. Security check required! Wait for phone... Phone found! [ 83 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just reinsert cable) on this step Reconnect Power/Cable! Last edited by AmirYeganeh; 10-21-2015 at 09:05. |
10-21-2015, 10:12 | #6 (permalink) |
Member: 2391357 Status: Offline Thanks Meter: 3 | i do that and my imei is ok now mut i have nv problem error in wifi search. my network have problem too can i write nv backup on desire 816G ? do you have nv backup for it ????? |
