12-06-2015, 12:18 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Do you need full control and extended features on "SmartAV"? Sure, copypasters not sleep and will copy it on day-two In few words - it allow make virus removing more comfortable and result will fully depend on user. It have 2 problem : 1. User IQ must be near 100 or more 2. It will give much fast ideas for other smart "teams" and let them be little better. In theory. |
The Following 7 Users Say Thank You to JayDi For This Useful Post: |
12-06-2015, 12:24 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Better will be just put update with those features , rest one - is simple. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
12-06-2015, 12:25 | #4 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: mystery city
Member: 1199392 Status: Offline Thanks Meter: 95 | Quote:
decrease full flashing time | |
12-06-2015, 13:18 | #6 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | It will Be Great.. There Should be Expert Mode In Setting Which Will Help User To Enable New Advance AV & Rest Option Only 4 Advance User. Rest User Will Use Simple AV Option & Other Without Knowing Too Much Br Vijay |
12-06-2015, 14:44 | #9 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Mindanao
Member: 1991929 Status: Offline Thanks Meter: 102 | sounds great...infinity team!!! will hoping will add for converting into .PAC,when i read flash SPD chips to flash in Research downloader...if possible. tnx infinity team! br: Yongitxt |
12-06-2015, 14:50 | #10 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
I not see reason for PAC yet. But, if will be need "just because someone made something at least near" - it will be activated. | |
12-06-2015, 15:00 | #12 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | InfinityBox CM2MTK Setup Closed When SmartAV Identify Code: Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50305858585810D5E194EEB071 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810D5E194EEB071 [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : delos3gzc ProdModel : GT-I8552 Device : delos3gchn AndroidVer: 4.1.2 MTKxCPU : MSM8225Q MTKxPRJ : ALPS.JB3.MP.V1 EXTRA : LCD [0] : rm68172 LCD [1] : otm8999_wvga_dsi_cmd LCD [2] : hx8369b_dsi_vdo LCD [3] : nt35510_dsi_cmd_6572 LCD Res : 800x480 TOUCH [0] : ft5206 TOUCH [1] : cy8ctma300 CAM [0] : hm5065_yuv CAM [1] : gc2145_yuv CAM [2] : s5k4ecgx_yuv CAM [3] : bf3905_mipi_yuv CAM [4] : sp0a19_yuv CAM [5] : gc2035_mipi_yuv CAM [6] : gc0329_yuv CAM [7] : gc0308_yuv CAM [8] : gc0328_yuv MODEM : hzcenon72_wet_jb3_hspa_a752 LOCALE : en_US fr_FR it_IT es_ES de_DE nl_NL cs_CZ pl_PL ru_RU ko_KR nb_NO es_US da_DK el_GR tr_TR pt_PT pt_BR rm_CH sv_SE bg_BG ca_ES en_GB fi_FI hi_IN hr_HR hu_HU in_ID iw_IL lt_LT lv_LV ro_RO sk_SK sl_SI sr_RS uk_UA vi_VN tl_PH ar_EG fa_IR th_TH sw_TZ ms_MY af_ZA zu_ZA am_ET hi_IN hdpi Done! Elapsed: 00:00:20 Reconnect Power/Cable! Code: Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50305858585810D5E194EEB071 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810D5E194EEB071 [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Sir JayDi New Smart AV Need For Test If Possible Thanks Anticipation |
12-06-2015, 15:59 | #14 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | |
