03-02-2007, 05:50 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | e122 Check Parameters Fail so i try to reset phone displaying follwing error COM3 selected Device: Nec E122 Checking data, wait... Action: Reset Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... file saved: Backup_eeprom-02_2007-3-2_10-13-4.83F.bin Check Parameters Fail Finished, time used: 73 sec Remove/Install battery now ! |
04-23-2007, 16:31 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | i also have this problem what should i have todo ? Log opened: [4/23/2007] [5:53:37 PM] App: C:\Program Files\InfinityBox\VModule\VModule.exe Loading data, wait... [Infinity Box] v1.22 S/N: xxxx:xxxx Wait... Current model: Audiovox GPRS748 Done Current model: Nec E122 COM3 ready WARNING ! Settings will be cleared, user data erased ! Continue ? COM3 selected Device: Nec E122 Checking data, wait... Action: Reset Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... file saved: backup_eeprom-02_20070423-180030.83F.bin Check Parameters FaiL Finished, time used: 350 sec Remove/Install battery now ! Br Faisal_Computer |
Jaf Pkey Access checking...Connecting Failed.. | irish_4 | J.A.F. By Jafsupport.com | 0 | 05-27-2008 07:20 |
Check the correct parameters | MSCOMMUNICATION | TORNADO - SIM | 3 | 04-14-2008 08:24 |
Nokia 2610 error "FAILED, check cable, Failed to Read" | Stylo_GSM | MT-BOX | 3 | 01-14-2007 15:41 |
HELP! GD75. check CRC FAILED | speedcomtop | Panasonic | 0 | 07-16-2003 02:00 |
HELP! GD75. check CRC FAILED | jamchat | Panasonic | 4 | 06-01-2003 07:45 |
