10-01-2016, 11:09 | #1 (permalink) |
Junior Member Join Date: May 2008
Member: 766231 Status: Offline Thanks Meter: 0 | Dongle is blocked, how to fix Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 01/10/2016 17:08:57 ---------- DongleManager [Infinity-Box] v1.65 [01/10/2016 17:08:57] PC HWID: CA1F650B5F536E5EBE02E52743CEA9E5 Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00003CE27CEA4082 Type: Main Infinity-Box/Dongle S/N: D3D13CE2 Version: 0130.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server reported error:[0031] Dongle identification data damaged. Contact to Smart-Card/Dongle/Box update Problems and Solutions - GSM-Forum |
10-01-2016, 14:15 | #2 (permalink) | |
What to do - How to fix: Dongle is blocked - GSM-Forum | |
10-03-2016, 16:04 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | please attach fault.bin file to your e-mail (rigtht now no file was attached) do you have this file ? |
10-05-2016, 00:10 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Ok, if fault.bin file was deleted or not found please explain what was the reason to use debugger at the same time with Infinity software. |
10-05-2016, 23:20 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Ok, ok. You do not know about debugger. 1. why do you run ollydbg siftwware at the same time with Infinity sofwtare ? 2nd qustion: what kind of cracked/pathced/hacked gsm software do you use at your PC ? |
