02-20-2020, 08:18 | #166 (permalink) |
Junior Member Join Date: Nov 2012 Location: Durban S.A
Member: 1843208 Status: Offline Sonork: kingunlocker Thanks Meter: 2 | while upgrading firmware. === DongleManager [Infinity] v1.72 [2/19/2020 23:15:42] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0109958124881292 === Process started: 2/19/2020 23:15:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
02-20-2020, 15:19 | #167 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
02-26-2020, 10:54 | #168 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Pakistan & UAE (Dubai) Age: 33
Member: 1526738 Status: Offline Sonork: 100.1607644 Thanks Meter: 6,688 | Hi Infinity Team this is My Friend Dongle Detail im Personaly check his pc i did not found fault.bin file in his pc even i can check his pc not have install any usb sharing Software pleas check and sort out problem Thank you === DongleManager [Infinity] v1.70 [2/26/2020 14:36:53] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0103846B1C6A1292 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): CFC2846B Firmware version: 0137.02 Box/Dongle misconfiguration Diagnostic code: 30 "UK Edition" status: Off Last launched Application: 0032 v.0137 => Activations: - 00: Infinity-Box/Dongle v.0137 Diagnostic Key: 7FCF5BEC5DBC9FC2 |
02-26-2020, 13:25 | #169 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,531 | Quote:
03-08-2020, 08:39 | #170 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | === DongleManager [Infinity] v1.74 [3/8/2020 9:35:54] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0007817218201292 Box/Dongle found: [BEST] Reading... Serial No (S/N): D76D8172 Firmware version: 0122.02 === Process started: 3/8/2020 9:35:55 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! what kind of this error how fix it |
03-08-2020, 10:42 | #171 (permalink) |
No Life Poster Join Date: May 2007 Location: TUNISIA Age: 40
Member: 500637 Status: Offline Thanks Meter: 424 | === DongleManager [Infinity] v1.70 [2020-03-08 10:36:27] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0002CDE4FF021982 === Process started: 2020-03-08 10:36:27 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
03-08-2020, 18:15 | #172 (permalink) | |
But you can try to update it once again now. Be sure that you hve only one dongle connected to PC when you run Infinity software. | |
03-08-2020, 18:16 | #173 (permalink) | |
03-08-2020, 18:40 | #174 (permalink) |
No Life Poster Join Date: May 2017 Location: Tajikistan Age: 30
Member: 2715751 Status: Offline Thanks Meter: 242 | === DongleManager [Infinity] v1.72 [08.03.2020 20:39:21] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000A7187F634082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): E076A718 Firmware version: 0138.02 === Process started: 08.03.2020 20:39:22 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
03-08-2020, 20:21 | #175 (permalink) | |
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
03-10-2020, 12:43 | #177 (permalink) |
Junior Member Join Date: Jun 2008 Location: Azerbaijan,Ganja city
Member: 803778 Status: Offline Thanks Meter: 2 | === DongleManager [Infinity] v1.72 [10.03.2020 15:42:14] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 1 HWID: 0000D02000001942 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 76C5D020 Firmware version: 0136.02 === Process started: 10.03.2020 15:42:18 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
03-10-2020, 13:07 | #178 (permalink) |
Freak Poster Join Date: Feb 2012 Location: paris
Member: 1719301 Status: Offline Thanks Meter: 132 | === DongleManager [Infinity] v1.70 [10/03/2020 13:04:26] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000E6891....... Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): ........ Firmware version: 0139.02 === Process started: 10/03/2020 13:04:28 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! but cm2mt2 doesn t launch,can you pls give us some explanations?IT ALWAYS ASKS FOR UPDATE |
03-10-2020, 13:45 | #179 (permalink) | |
Please fix your PC according to instruction for error #57 - https://www.infinity-box.com/support/?r=4 After that update dongle firmware with DongleManager. | |
03-10-2020, 13:45 | #180 (permalink) | |
It looks like your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ | |
