-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Dongle misconfiguration - How to fix (http://forum.gsmhosting.com/vbb/f296/dongle-misconfiguration-how-fix-2588849/)
adlene2005 04-27-2019 14:47
please active my dongle
=== DongleManager [Infinity] v1.70 [27/04/2019 14:45:16] ===
Searching...
Card-Reader: SCM Microsystems Inc. SCR33x USB Smart Card Reader 0
HWID: 0002926620281292
Box/Dongle found: [BEST]
Serial No (S/N): 96049266
Firmware version: 0122.02
Box/Dongle misconfiguration
Diagnostic code: 30
"UK Edition" status: Off
Last launched Application: 0034 v.0137
=> Activations:
- 00: Infinity-Box/Dongle v.0137
- 03: [BEST] v.0122
- 07: module #07
Diagnostic Key: 7F743C8F29D1308F
muhned 04-27-2019 15:00
result :
=== DongleManager [Infinity] v1.72 [27/04/2019 16:49:38] ===
Searching...
Card-Reader: Generic CCID Smart Card Reader 0
HWID: 0007647114D11292
Reading...
Serial No (S/N): 7A506471
=== Process started: 27/04/2019 16:51:40 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
show error
scard transmit error
smart card api error #2148532271
achraf1979 04-27-2019 16:31
Originally Posted by InfinityHelp (Post 13636250)
what was the reason to trace Infinity software usb communication ?
I have a tool in myvpc but not used with infinity software or any tool servicing gsm
Its for other service
InfinityHelp 04-27-2019 19:34
Searching...
Diagnostic code: 30
=> Activations:
- 03: [BEST] v.0122
- 07: module #07
Hello,
- Run DongleManager
- Update Dongle firmware now
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
InfinityHelp 04-27-2019 20:04
Originally Posted by muhned (Post 13636313)
result :
Searching...
Reading...
show error
As I can see card was updated well after that.
right ?
InfinityHelp 04-27-2019 20:19
Update dongle firmware now.
Next time (if any) I am afraid it will be no such ability any more.
muhned 04-28-2019 14:02
replace other smart card reader and update smart card ok
but not open after update cm2mt2
log
=== DongleManager [Infinity] v1.72 [27/04/2019 20:27:17] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
Reading...
=== Process started: 27/04/2019 20:27:18 ===
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
=== DongleManager [Infinity] v1.72 [27/04/2019 20:28:40] ===
Searching...
"UK Edition" status: On
Last launched Application: 0030 v.0158
=> Activations:
- 00: Infinity-Box/Dongle v.0136
- 03: [BEST] v.0122
why cm2mt2 not opening
InfinityHelp 04-28-2019 14:26
log
Searching...
Reading...
Searching...
=> Activations:
- 03: [BEST] v.0122
Hello,
It looks like your dongle support period is expired.
How to check - https://www.infinity-box.com/doc/?r=17
If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/
muhned 04-28-2019 15:07
thanks good support
regards
sajid r shaikh 05-11-2019 16:02
please help infinity team solve my problem
=== DongleManager [Infinity] v1.72 [5/11/2019 20:24:21] ===
Searching...
HWID: 00078C8508771292
Box/Dongle found: CDMA-Tool
Serial No (S/N): 45E58C85
Diagnostic code: 30
Last launched Application: 0034 v.0136
=> Activations:
- 01: CDMA-Tool v.0122
- 07: #7
Diagnostic Key: 7FC2E296655B8B5A
sajid r shaikh 05-11-2019 16:30
please help infinity team fast work pending on my table . please solve my problem fast
InfinitySupport 05-12-2019 20:45
Searching...
Diagnostic code: 30
=> Activations:
- 07: #7
You have got an answer via e-mail already
Artemius 06-01-2019 07:12
=== DongleManager [Infinity] v1.72 [31.05.2019 15:14:45] ===
Searching...
HWID: 00009E8E0EFE4082
Box/Dongle found: Infinity-Box/Dongle
Serial No (S/N): B8619E8E
Firmware version: 0137.02
Diagnostic code: 5A
Last launched Application: 0030 v.0137
=> Activations:
- 03: [BEST] v.0122
- 07: #7
Diagnostic Key: 7F721D3DDBE139B2
It's happen after i was install programmer CH431A on PC but i need this for flashing routers, Please help
YellowBoss 06-01-2019 07:44
Searching...
Diagnostic code: 5A
=> Activations:
- 03: [BEST] v.0122
- 07: #7
Hello,
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software.
What to do now:
- Delete fault.bin file from software folder (if you have it there)
- Install latest Infinity software updates
- Run DongleManager
Aymen2net 06-10-2019 12:12
=== DongleManager [Infinity] v1.72 [10/06/2019 12:02:41] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 01089B5924881292
Reading...
Serial No (S/N): 0FDA9B59
=== Process started: 10/06/2019 12:02:42 ===
Server answer:[0031] Dongle identification data damaged.
Contact to http://www.infinity-box.com/support/?r=2
i uninstalled it and reinstall again also i deleted all softwares that could lead to that error but same probleme
Page generated in 0.33098 seconds with 5 queries
