Old 06-10-2019, 14:13   #31 (permalink)
Member: 148515
Thanks Meter: 15,722
Originally Posted by Aymen2net View Post
=== DongleManager [Infinity] v1.72 [10/06/2019 12:02:41] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 01089B5924881292
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): 0FDA9B59
Firmware version: 0122.02
=== Process started: 10/06/2019 12:02:42 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Contact to http://www.infinity-box.com/support/?r=2
i uninstalled it and reinstall again also i deleted all softwares that could lead to that error but same probleme
Attach fault.bin file here or send e-mail with file and problem info to:
help [at] infinity-box.com
Old 06-10-2019, 14:25   #32 (permalink)
Member: 2736155
Thanks Meter: 8
[IMG][/IMG]
i couldn't find fault.bin
Old 06-11-2019, 12:09   #33 (permalink)
Member: 2736155
Thanks Meter: 8
now it shows error dongle blocked
Old 06-11-2019, 16:29   #34 (permalink)
Member: 148515
.... also i deleted all softwares that could lead to that error but same probleme
What was that software ?
Old 06-12-2019, 09:54   #35 (permalink)
Member: 2736155
Thanks Meter: 8
Cracked softwares, team viewer... ( it worked well before even when cracked softwares was there)
Old 06-12-2019, 09:59   #36 (permalink)
Member: 2736155
Thanks Meter: 8
The probleme started when i inserted a multimedia hard drive and installed drives.... After that the probleme started. " Memup " i installed setup and drivers... Help please i need infinity to work again because i use it alot
Old 06-12-2019, 12:53   #37 (permalink)
Member: 2736155
Thanks Meter: 8
i tried even to install it on another windows but same error ... what is happening ? whats the probleme ?
Old 06-12-2019, 20:15   #38 (permalink)
Member: 148515
@Aymen2net
update dongle firmware now
Old 06-13-2019, 11:49   #39 (permalink)
quasim0438's Avatar
Member: 237155
Thanks Meter: 398
Unhappy plz solve my problem.
warning. dongle misconfiguration.
=== DongleManager [Infinity] v1.70 [6/13/2019 14:41:18] ===
Searching...
HWID: 0103866B20281292
Serial No (S/N): EDC8866B
Box/Dongle misconfiguration
Diagnostic code: 30
"UK Edition" status: Off
Last launched Application: 0031 v.0127
=> Activations:
- 00: Infinity-Box/Dongle v.0136
- 03: [BEST] v.0122
Diagnostic Key: 7F33EC86B5E64345
Old 06-13-2019, 13:27   #40 (permalink)
Member: 148515
Searching...
Diagnostic code: 30
=> Activations:
- 03: [BEST] v.0122
As I can see it's already fixed. Right ?
Old 06-27-2019, 12:34   #41 (permalink)
Member: 2729556
Please HELP...
=== DongleManager [Infinity] v1.72 [27.06.2019 13:28:54] ===
Searching...
HWID: 000127C57D314082
Box/Dongle found: Infinity-Box/Dongle
Serial No (S/N): DB7527C5
Firmware version: 0137.02
Diagnostic code: 5A
Last launched Application: 0030 v.0137
=> Activations:
- 00: Infinity-Box/Dongle v.0137
Diagnostic Key: 7F77B5FC191C3862
При запуске любой программы пишет "Dongle misconfiguration"... Уже не знаю что делать
Old 06-27-2019, 17:16   #42 (permalink)
Member: 1043909
Thanks Meter: 52,180
Searching...
Diagnostic code: 5A
=> Activations:
Hello,
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software.
What to do now:
- Delete fault.bin file from software folder (if you have it there)
- Install latest Infinity software updates
- Run DongleManager
- Update Dongle firmware
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
Old 07-13-2019, 18:24   #43 (permalink)
Member: 918165
Sonork: ayaz p
Thanks Meter: 2
card config errr
=== DongleManager [Infinity] v1.72 [7/13/2019 21:21:10] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 000019E50EFE4082
Serial No (S/N): B4D119E5
Diagnostic code: 5A
Last launched Application: 0036 v.0137
=> Activations:
- 07: #7
Diagnostic Key: 7FCF0BF2BBD9139E
=== DongleManager [Infinity] v1.72 [7/13/2019 21:23:28] ===
Box/Dongle type selected: Infinity-Box/Dongle
Reading...
=== Process started: 7/13/2019 21:23:30 ===
Old 07-13-2019, 21:10   #44 (permalink)
Member: 1043909
Searching...
Diagnostic code: 5A
=> Activations:
- 07: #7
Reading...
Hello,
What to do now:
- Run DongleManager
Old 07-14-2019, 11:05   #45 (permalink)
Member: 889279
Sonork: rumaragasa
=== DongleManager [Infinity] v1.72 [7/14/2019 17:03:16] ===
Searching...
HWID: 0000C4B81A224082
Reading...
Serial No (S/N): 331DC4B8
Firmware version: 0136.02
=== Process started: 7/14/2019 17:03:18 ===
Page generated in 0.18088 seconds with 8 queries
