11-04-2009, 09:50 | #7 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Romania Age: 54
Member: 6797 Status: Offline Thanks Meter: 14 | Hi, Mine is also dead from yesterday. I unlock an kp107 like kp105, then I try to read fullflash , sw hangs, after a while I reset the computer and leave the idea to read kp107. Today when I try dongle, I found it dead. Here are some pictures. I look at dongle and physical looks ok. Need some help from infinity team to revive dongle. Thanks |
11-04-2009, 12:13 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to insert smart-card in another card-reader (f.e setool etc.) and see results. Also you can try to remove card from box, gently clean smart-card contacts, insert card back. |
11-04-2009, 14:01 | #10 (permalink) |
Member: 6797 Status: Offline Thanks Meter: 14 | I clean up contacts, I check for continuity and is ok, but same result dongle not found. I see this is a simply card reader. Other card reader that I have are usbsmart and jaf but are with atmega64 inside. Can I try with one of theme? |
11-05-2009, 00:55 | #11 (permalink) | |
Usbsmart card reader is not compatible with e-gate smart cards. It is need to use the same easy card reader (f.e Setool, Cruiser, Vygis). | |
11-05-2009, 17:13 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If card can not be detected with another card-reader it may be that card (as any other hardware) become damaged. If your box is under warranty period, you can contact to your reseller to talk about warranty (any kind of this procedure should be done via reseller, we do not make any replacement directly). If box is quite old you need to buy another smart-card. |
11-06-2009, 08:38 | #14 (permalink) | |
Member: 6797 Status: Offline Thanks Meter: 14 | Quote:
Yes my box is old, also in excelent condition and I thought there is a way to buy from the source or from an reseller just a replace card (like a postwarranty), not again the box with 2xx EUR. If my car has ECU damaged, I buy a new one, not a new car. Isn't that possibly? | |
11-07-2009, 02:16 | #15 (permalink) | |
It's possible to buy just a smart-card, it should be cheaper than full box set. Try to ask nearest resellers about cards. In case of any problems you can contact to our sales department directly: [email protected] | |
blackberry dongle applet not found | jybx | FuriousGold | 15 | 09-08-2010 17:58 |
infinity dongle is not update not enter in suppot side | khanzafar | Infinity-Box | 1 | 04-30-2009 15:40 |
SST dongle driver not found Problem | kabirhossain | SST-Dongle | 5 | 07-05-2008 21:32 |
Hard Drive is not found | jittujain | Nokia Base Band 5 ( BB-5 ) | 7 | 03-08-2007 19:19 |
Hard Drive is not found | jittujain | Nokia Base Band 5 ( BB-5 ) | 2 | 01-15-2007 09:08 |
