Old 07-03-2018, 15:36   #1 (permalink)
Member: 2413485
Thanks Meter: 14
Doogee bl7000 DA : SETUP EMI PARAMS FAILED!
Operation : Identify [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM5)
MODE : BOOTROM
PORT : 5
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000001
BROM : SecMode : SBC
BROM : BOOTROM
MODE : 0_base : BASE_v1724 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6755
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 0009
EMI : Init EMI from INTERNAL DB
ERROR : ABORT
Error : Fail to init protocol!
Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
Reconnect Power/Cable!
Old 07-03-2018, 15:49   #2 (permalink)
Member: 2413485
Thanks Meter: 14
If write flash:
Operation : Write Flash [ v2.00 r4 ]
Repartition : Enabled
Flash Verify : Disabled
Pre-Erase : Enabled
Verify HW/SW : Enabled
XData Backup : Disabled
Files :16
[FL] : Set : preloader_pri6750_66_n.bin
[FL] : Set : recovery.img
[FL] : Set : md1rom.img
[FL] : Set : md1dsp.img
[FL] : Set : md1arm7.img
[FL] : Set : md3rom.img
[FL] : Set : lk.bin
[FL] : Set : lk2.bin
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : trustzone1.bin
[FL] : Set : trustzone2.bin
[FL] : Set : secro.bin
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0xE99C5EEC [ 3,65 GB ]
PTFN : MediaTek USB Port (COM9)
MODE : BOOTROM
PORT : 9
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
MODE : 0_base : BASE_v1712 | Manual : Disabled
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6755
EMI : SRC : preloader_pri6750_66_n.bin
EMI : CNT : 0001
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256,00 KB ]
DRAM: 0xC0000000 [ 3,00 GB ]
EMMC: 450100444634303634013986ED8A7451
EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4064
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x00400000 [ 4,00 MB ]
USER : 0xE8F800000 [ 58,24 GB ]
CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : E643A0D5234D0D885AD2BB7A72D3B912
DA : USB : FULL-SPEED
Error : Failed to setup HS_USB port!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Old 07-03-2018, 16:22   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Check driver.
And select base 1812/1816 and repeat process.
Br.
Infinity Box Team.
Old 07-04-2018, 13:19   #4 (permalink)
Member: 2413485
Thanks Meter: 14
not work sir.
different pc and drivers but same error.
but phone work ok.
can in software disable usb full-speed?
and write in normal speed?
Old 03-03-2021, 14:23   #5 (permalink)
Member: 797068
Thanks Meter: 75
FATAL ERROR : NO ANY STORAGE DETECTED! Device HW fault or TestPoint hold!
Card found : 0EXXXXX , v0147
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21
Load IDBase v21168 Ok!
Preloader [HW DEV] Info :
EMI : DEV : MT6755
EMI : CNT : 0001
EMI : [00] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4,00 GB ]
Operation : Write Flash [ v2.21 ]
Reg.Pre-Erase : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Flash Format : Disabled
Files :16
[FL] : Set : lk.bin
PTFN : MediaTek USB Port (COM3)
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
BROM : MEID : 8FBD7F43395B128ED7AE8B7896BE8902
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v1812 | Manual : Disabled
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6755
EMI : CNT : 0001
EMI : Init EMI from PRELOADER
DRAM: 0x00000000 [ 0 B ]
RNID : B10C454AD8C322FCA10A5BCF7C588EA
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM46)
MODE : PRELOADER PORT
PORT : 46
Old 03-03-2021, 14:32   #6 (permalink)
Member: 797068
Thanks Meter: 75
Card found : 0EXXXXXX , v0147
Operation : HW Report [ v2.21 ]
HWreport : Mode : eMMC
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0007
ERROR : ABORT
Boot done!
Memory Info :
DAT : Size: 30 MB, Max.Speed: 20000 kHz, blklen(512), nblks(62688), ro(0)
Overall status :
Done!
Elapsed: 00:00:56
Old 03-04-2021, 16:05   #7 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
FlashIc failure. Check Hw first.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-04-2021, 16:32   #8 (permalink)
Member: 797068
Thanks Meter: 75
see
Page generated in 0.18169 seconds with 8 queries
