10-31-2017, 10:48 | #1 (permalink) |
Freak Poster Join Date: Jul 1999 Location: Bulgaria
Member: 327 Status: Offline Thanks Meter: 6 | DOOGEE MIX NVRAM backup need Model is 6gb ram/64GB. Phone is with erased nvram after format with SP Flash Tool. Phone not have IMEI and baseband. If someone has nvram backup or such a phone and can make a nvram.img backup with SP Flatsh tool. Also cant duet any operation with CM2MTK. Here is log: Chinese Miracle II [MTK module] v 1.58 Start at : [31.10.2017 Ј. / 11:41:56] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 0551 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0001 Processing BROM stage Settings for BROM configured! SecCfgVal : 0xE1000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : Unknown Mode! Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! Finish at : [31.10.2017 Ј. / 11:42:00] Thank you in advance. |
10-31-2017, 17:37 | #2 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: Bulgaria
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Quote:
Download and flash latest firmware :https://www.needrom.com/download/doogee-mix/ Doawnload and learn how to use MAUIMETA :https://forum.hovatek.com/thread-12328.html Change NVRAM database and write your original imei number | |
11-02-2017, 12:13 | #3 (permalink) |
Member: 327 Status: Offline Thanks Meter: 6 | @vasko_bojilov Thank you for answer. I know how to work with Mauimeta. I tried different versions, but almost always get connection errors. Only with SP Meta Ver. 1.1620.00 connect, but there is no imei tool. Here's an error picture with another version. There may be a need to restore nvram backup from other phone and correct imei after this. |
11-03-2017, 09:12 | #4 (permalink) | |
DID you try via that? https://drive.google.com/file/d/0B9e...VqQktuMzQ/view 14.START IMEI&SN_WRITER_TOOL.EXE 15.UNDER PLATFORM SELECT "SMARTPHONE" 16.CHECK USB OPTION IS SELECTED 17.IN WRITE ITEM SECTION TICK IMEI_1,IMEI_2,WIFI 18.TYPE IMEI_1 & IMEI_2(WHICH MUST BE WRITTEN AT THE BACK OF THE MOBILE) 19.TYPE WIFI ADDRESS(WITHOUT COLLEN) 20.SEE GREEN TICK MARK MUST COME NEXT TO THE IMEI_1,IMEI_2,WIFI TEXTBOX 21.NOW TICK IMEI_1,IMEI_2,WIFI FROM READ ITEM SECTION 22.SELECT START BUTTON 23.NOW SELECT THE MODEM DB FILE(STARTS WITH "BPLG...",WILL GET THIS FILE IN STOCK ROM) 23.NOW SELECT THE AP DB FILE(STARTS WITH "AP...",WILL GET THIS FILE IN STOCK ROM) 24.NOW LOOK AT THE MESSAGE BOX 25.CONNECT PHONE WITH USB TO PC WITHOUT BATTERY & SIM & MEMORYCARD 26.LOOK IN THE MESSAGE BOX FOR ITS DONE STATUS 27.NOW SWITCH ON MOBILE 28.CHECK IF IMEI IS FIXED BY TYPING THE CODE *#06# 29.CHECK FOR WIFI ALSO 30.THATS IT, ITS DONE IMEI & NVRAM IS FIXED PERMANENTLY | |
11-04-2017, 09:37 | #5 (permalink) |
Member: 327 Status: Offline Thanks Meter: 6 | @vasko_bojilov With IMEI&SN Writer V1.5.3 cant conntct with phone. After click Start button immediately get Bootup fail!!! error. With other version IMEI&SN Writer can connect but final get also error. Here is screenshots. |
