Old 05-24-2016, 17:46   #1 (permalink)
Member: 2102145
Thanks Meter: 10
alcatel 4013x dead after flash
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 15010046355835434201ED5DC6A842AD
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:38
Reconnect Power/Cable!
Old 05-25-2016, 13:23   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Post flashing log here
per now you need preloader file to make it alive. Before flashing good firmware.
Old 12-08-2017, 01:17   #3 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
Operation : Flash [ v1.58 ]
======= Flash
Files set for flashing :
[ MCU ] : MT6572__TCL__4013X__Pixi3-4__ALPS.KK1.MP6.V1__Android_4.4.2__18.06.2015.ispf f
Wait for phone...
Phone found! [ 61 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
eMMC Flash : 15010046355835434201BC4FC2D22283
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:11
same...how to fix fone????
Old 12-08-2017, 02:07   #4 (permalink)
Member: 2682716
Thanks Meter: 10
reheat flash ic mate
Old 12-08-2017, 02:08   #5 (permalink)
Member: 2682716
Thanks Meter: 10
plug directly the usb. do not hold boot keys as what the logs saying. if no luck, use sp flash tool
Page generated in 0.11656 seconds with 8 queries
