09-29-2017, 16:18 | #1 (permalink) |
Freak Poster Join Date: Nov 2016 Location: Everywhere
Member: 2647496 Status: Offline Thanks Meter: 40 | DOOGEE X10 Boot error Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 124 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
The Following User Says Thank You to savanaunlok For This Useful Post: |
09-29-2017, 17:59 | #2 (permalink) |
Member: 2647496 Status: Offline Thanks Meter: 40 | Well. Anyway, I needed to get rid of frp so I unlocked bootloader and removed frp via fastboot mode. Might be of help to others |
01-30-2018, 12:09 | #3 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | wait for new version originally post by jaydi Code: - > Reading device Info [NAND] BRAND : DOOGEE DEVICE : DOOGEE X10 PLATFORM : MT6570 ANDROID : 6.0 SEC_PATCH : 2017-05-05 Done! Elapsed: 00:00:18 |
The Following User Says Thank You to malka4u For This Useful Post: |
03-03-2018, 09:28 | #4 (permalink) |
Freak Poster Join Date: May 2003 Location: Poland Age: 46
Member: 27843 Status: Offline Sonork: 100.1646294 Thanks Meter: 26 | pls help phone stuck in logo doogee Card found : S/N : 0986DDB4 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following User Says Thank You to gsmline For This Useful Post: |
