10-06-2008, 10:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: UNITED KINGDOM Age: 44
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 339 | Doro handleeasy 328gsm made in sweden www.doro.com its that phone supported please br karim |
10-06-2008, 18:00 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, This phone can be supported fast. As I can see from your picture pin-1 is GND, pin 8 is Charge. You need to find Rx/Tx pins and you will be able to serve this phone with ChineseMiracle. btw, how to count pins ? is your connector photo was made with keyboard up or down ? Also, if you will be able to fid pinout and read flash, pls send flash backup to [email protected] |
10-16-2008, 12:36 | #11 (permalink) |
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 339 | founf it software version: 1.14 cable type: 1x8 (L8A) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM2... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6223 result: Rx:2 Tx:4 time required: 5 sec Power On ! i will try to read flash and send it br karim |
The Following User Says Thank You to KARIM GSM-ZONE For This Useful Post: |
10-16-2008, 15:06 | #12 (permalink) |
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 339 | thx to infinityteam for the hellp ok phone unlocked and work perfect but it s give me erreur after unlock, im sure phone locked before. flash been sent to infinity support COM2 [VCP0] selected module v2.64 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:66FC:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #01 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #02 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #03 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #04 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #05 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #06 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #07 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #01 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: CKT23_NEP324_07A_PCB01_GSM_MT6223_S00.EASYUSE3_DOR O328_DORO_L1EN_201_080529_IDW_SS53.BIN ver. sw2: EASYUSE3_DORO328_DORO_L1EN_201_080529_IDW_SS53, 00000000 ffs offset/size: 00300000/00100000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00300000 flash: EC257E25032501:2AEA0000000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 003A0000 Detected eeprom/ffs address is non-standard: 003A0000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[003A0000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00060000 ffs chip: 00 eeprom/ffs area: 00000000:003A0000-003FFFFF detecting ffs structure pass 1... ...... detect standard fat location pass #1... ............... detect extended fat location pass #1... ........ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[CKT23_NEP324_07A_PCB01_GSM_MT6223_S00.EASYUSE3_DOR O328_DORO_L1EN_201_080529_IDW_SS53.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[CKT23_NEP324_07A_PCB01_GSM_MT6223_S00.EASYUSE3_DOR O328_DORO_L1EN_201_080529_IDW_SS53.BIN]_20081016-064639.B0E.bin flash: EC257E25032501:2AEA0000000000 Backup required data Done Patch required data... detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail Finished, time used: 83 sec Remove/Install battery now ! here is the pinout regards karim |
Doro PhoneEasy 345gsm SIM LOCKED TO ORANGE FRANCE | gsm-nisse | Infinity-Box | 35 | 06-14-2011 19:00 |
Doro PhoneEasy 345gsm not unlocked | kimo59 | Infinity-Box | 13 | 11-25-2010 19:00 |
Doro PhoneEasy 410 US, unlock? | rcll2 | Various | 2 | 07-05-2010 15:29 |
04 Mar 2010: Doro-338gsm, 326gsm models supported | YellowBoss | Infinity-Box | 6 | 03-08-2010 02:09 |
08 Nov 2009: Doro, ZTE, Philips, Alcatel, Virgin models supported | InfinitySupport | Infinity-Box | 28 | 12-18-2009 14:44 |
