02-07-2011, 15:25 | #2 (permalink) |
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | LOGS>>>>>>>>>>>. COM19 [VCP0] selected module v3.73 Device: Doro-PhoneEasy-410s Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5E88:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: SHELL_S09_PCB01_GPRS_MT6223_S00.SHELL_S09_2V8_DORO 410_L14EN_202_100521_MCP128+32_BT_FM_SMS.BIN project-id: SHELL_S09_2V8_DORO410_L14EN_202_100521_MCP128+32_B T_FM_SMS, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:29EA0000000000 Backup required data Done ====> Patch required data ... ......................................... lock area found ......................................... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch detecting parameters to apply patch area 2... .................................................. .............. error: area 2 can not apply patch Special operation Done ====> Write ... flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: lock-area-1 flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 53 sec Remove/Install battery now ! AK' |
02-08-2011, 03:57 | #4 (permalink) |
Freak Poster Join Date: Mar 2007 Location: In the skies
Member: 460298 Status: Offline Thanks Meter: 32 | can't you see: error: area 1 can not apply patch detecting parameters to apply patch area 2... .................................................. .............. error: area 2 can not apply patch |
02-09-2011, 19:29 | #7 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Dakar
Member: 1415435 Status: Offline Sonork: 1595155 Thanks Meter: 86 | hard reset , flash +eeprom , then unlock again ( read codes , it is safer for you ) |
The Following User Says Thank You to SenUnlock For This Useful Post: |
02-10-2011, 09:51 | #8 (permalink) | |
Yes, we see your post well, but we need some time to check what may be the problem. I am sure you understand that to check something we need to take phone on hands and make many tests, and this can not be done in 1 minute. So be sure - we read EACH POST IN THIS FORUM VERY CAREFULLY ! But we are a professional people and we do not want to give fast & stupid advices (you know many examples of people who give fast & stupid advices instead of think before post an advice). We must think well and make additional tests before post an answer here. | |
02-12-2011, 11:44 | #10 (permalink) |
Member: 1442994 Status: Offline Thanks Meter: 899 | UNLOCK DONE COM19 [VCP0] selected module v3.74 Action: read unlock codes unlock method: read codes Model: Doro-PhoneEasy-410s Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5E88:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: SHELL_S09_2V8_DORO410_L14EN_202_100521_MCP128+32_B T_FM_SMS Version: CKT23D_08A_HW 80 byte(s) read imei: 35759603195541 connection Ok 191 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 179 byte(s) read reading data... 972 byte(s) read lock[1] code: + 65995367 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 12 sec Remove/Install battery now ! thanxxxxxxxxxxxxxxxxxxxxxxxxx AK' |
The Following 2 Users Say Thank You to AbDuLlAH kHaWaR For This Useful Post: |
02-12-2011, 12:09 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @AbDuLlAH kHaWaR Thanks a lot for test report ! If you still have phone on hands, please, read full flash from this phone and send full flash backup (or RapidShare AG, Cham, Switzerland link) to [email protected] Thank you ! |
02-12-2011, 14:01 | #13 (permalink) |
Member: 472000 Status: Offline Sonork: 100.1606407 Thanks Meter: 25 | http://rapidshare.com/files/44753024...1019_MCP128_32 i have not unlock done with this firmware please help me YellowBoss |
02-12-2011, 14:21 | #14 (permalink) | |
Did you tried to unlock phone with latest MModule software ? What is the results ? | |
02-12-2011, 14:53 | #15 (permalink) |
Member: 472000 Status: Offline Sonork: 100.1606407 Thanks Meter: 25 | i have use the latest mmodule 3.74 i tested all methode to unlock the soft detect firmware missing in support and this code errone lock[1] code: + 12345678 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 |
