Old 06-09-2011, 20:21   #1 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
is Doro PhoneEasy 410gsm Supported?
I see Doro PhoneEasy 410s is supported BUT cant see 410gsm. I tried unlocking by selecting 410s but get no response.
So I'm asking is Doro PhoneEasy 410gsm unlock supported by infinitybox?
Old 06-10-2011, 05:31   #2 (permalink)
Member: 1043909
Thanks Meter: 51,759
Hello,
What is exact text from your phone back label ?
What cable/pinout you have used ?
Post here operation log text.
Old 06-10-2011, 11:40   #3 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
Originally Posted by YellowBoss View Post
Hello,
I used pinout as 410s because looked the same board.
==== [09/06/2011 18:34:14] ====
COM77 [VCP0] selected
module v3.92
Action: read unlock codes
unlock method: read codes
Model: Doro-PhoneEasy-410s
Checking data, wait...
error: can't activate test mode
error: operation failed !
Finished, time used: 48 sec
Remove/Install battery now !
No action is observed on fone
when I try read phone
Action: read/check information
Phone should be Switched ON !
Connecting, wait...
error: connection failed !
If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect")
operation failed !
Finished, time used: 42 sec
fone switches on but nothing happens on pc
Old 06-11-2011, 14:27   #4 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
Is this phone Supported or Not???
Old 06-14-2011, 00:37   #5 (permalink)
Member: 1043909
Hello,
Sorry for late reply.
As I can see this phone has another mark in compare with ordinary 410s.
Could you, please, open phone and check what is this phone CPU chip name.
Also, try to type *#0044# w/o sim.
What you see at phone LCD ?
Old 06-14-2011, 11:11   #6 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
Hello,
I tried typing in that code without sim but nothing happens and if I press call button after then It says "English set"
I took photo of inside, hope that helps
Old 06-14-2011, 13:05   #7 (permalink)
Member: 1043909
Hello,
PCB is very similar to 410s (probably even the same) and I am sure that phone can be connected to software and at least we can read flash.
If phone can not be detected by software yet, please, double check pinout, (probably you have to swap Rx <-> Tx wires) and try to read full flash once again.
If you will be able to read flash - try to make "read codes" too.
Waiting for your results.
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 06-14-2011, 14:56   #8 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
Hello,
I tried changing rx and tx but phone turned on when trying unlock so assumed was correct in begining so soldered connections to board and succes so can confirm 410gsm is same unlock as 410s although I didnt try direct unlock only codes.
COM9 [VCP0] selected
module v3.92
error: boot initialization step #2 failed: 00
19200 autodetect
Initializing [6223:8A08]...
CPU: MT6223
chip: 0011:7B60:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E08
Date: 2000.00.00
Version: 1.0
Version: SHELL-S09_2V8_DORO410_L14EN_204_101020_MCP128+32_BT_FM_SMS
Version: CKT23D_08A_HW
80 byte(s) read
imei: 35759603383768
connection Ok
191 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
179 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 69947926
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if phone do not ask for a code try: *983*8284#
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone (do not remove battery)
- read unlock codes
- restore original imei
Finished, time used: 9 min 57 sec
Thank you Very Much for your good support.
Old 07-06-2011, 20:34   #9 (permalink)
fonefun's Avatar
Member: 26187
Sonork: 100:77458
Thanks Meter: 288
we made cables today for doro 409s and 410s should you need one
and yes it works on the 409gsm too, we unlocked the one pictured below
lot easier than soldering ;-)
available @ Acer Doro 409s - 410s Test Point Cable For Infinity Box
The Following User Says Thank You to fonefun For This Useful Post:
Old 07-25-2011, 10:20   #10 (permalink)
:::..CyBoRg..:::'s Avatar
Member: 568876
Thanks Meter: 82
doro phoneeasy 409s gsm unlocked done via read codes........
COM7 [VCP0] selected
module v3.75
19200 autodetect
CPU: MT6223
chip: 0011:5FED:000C
status: FF
Date: 2000.00.00
Version: 1.0
Version: SHELL-S21_1V8_DORO409S_L15EN_201_110107_MCP128+32_SMS
80 byte(s) read
imei: 35682404008323
connection Ok
191 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
179 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 12345678
lock[2] code: + 56781234
lock[3] code: + 84064789
lock[4] code: - 3344
lock[5] code: - 5566
lock[6] code: + 7788
lock[7] code: + 9900
- Power-Off phone
- read unlock codes
Finished, time used: 1 min 17 sec
The Following User Says Thank You to :::..CyBoRg..::: For This Useful Post:
Old 07-26-2011, 10:23   #11 (permalink)
Member: 1043909
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? telefonman Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-13-2000 20:06
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 15:31
Page generated in 0.49416 seconds with 9 queries
