08-30-2018, 20:41 | #1 (permalink) |
No Life Poster Join Date: Nov 2016 Location: iran tehran 021
Member: 2643931 Status: Offline Sonork: ****** Thanks Meter: 225 | ::.Problem running some programs on my computer.:: I even changed the windows I formatted the hard disk I scanned the computer with a virus But the problem persists When i change windows Just 5 minutes is good ---------------------------- My problem is this error the application error x0c000005 This error affects these programs-->> sp flashtool-- itunes-- moborobo --qoualcom driver--adb --infinity dongle For example, when I get out of the zip, it's sp flashtool There is no problem for 3 to 4 minutes But then it makes a mistake again That I must erase And again from the zip And use it I have not been able to erase this error for 6 months And maybe I change windows more than 70 times And do all the solutions available on the Internet I did not give it I heard this problem from the computer memory(RAM) that my friends said is it correct? |
08-31-2018, 09:33 | #5 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | More specifically, these errors can be caused by: Corruption of files in the system. Problems with hardware. Incompatible or outdated driver. Malware infection or virus that corrupted any file. Third-party software that has mistakenly or maliciously deleted files related to the system. In relation to your question, to be more assertive for kindness report: What is the manufacturer and model of your device? Did you recently add or change some hardware? Sometimes is your windows its a bad "copy" advice "buy" or "download" another windows from trusted sources. Last edited by yuranc8; 08-31-2018 at 09:39. |
08-31-2018, 16:14 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | @afghanistanmob Hello, This error could be due to several reasons- -Virus, Malware etc -Antivirus conflict -Registry problem -Bad Driver -Windows -Ram -And lastly HDD So you need to check thoroughly step by step what is causing problem. Br. Infinity Box Team. |
08-31-2018, 18:56 | #9 (permalink) |
Member: 2643931 Status: Offline Sonork: ****** Thanks Meter: 225 | Thank you all But I did all this But the problem is still there I just did not test the RAM and hard drive Can it be recognized that it is corrupted or healthy (RAM & Hard drive) With a special program (Tools) |
09-02-2018, 13:55 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | as a first step you can test RAM with builtin windows RAM test tool. to test HDD you can use windows builtin tools also, run test with bad blocks check. also very useful tool to monitor your HDD health at regular base is CrystalDiskInfo - https://crystalmark.info/en/ |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
