02-06-2008, 12:48 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | DTS11 can not format ffs seccont CPU!! Regards COM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... CPU: MT6205 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 115 sec Remove/Install battery now ! |
02-06-2008, 20:19 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! to get connection and boot second MCU you must hold power button very long. about 30seconds. first you will get no reaction and while this phone will power On. you must still keep power button pressed. After some time first phone part will start and then it will call to boot second part. did you follow this like i said or released button earlyer? Try to use Complete Format and IMEI writing method-3 |
02-11-2008, 12:29 | #3 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | Actually Client has gone! anyway I respond you. after soft says press power on, I pressed and did not released until it say me the error above each time.. regards |
Pinfinder can not find pin spreadtrum cpu | Shohel_sst | Infinity-Box | 6 | 06-02-2011 20:34 |
Can not format i68+ CPU MT-6225 | 4 u man | SpiderMan | 2 | 10-18-2009 09:44 |
Can not format any spd cpu, help me please | himanshu taldar | CPF-BOX Ⅱ | 3 | 03-01-2009 16:07 |
Ztc 618 Reboot-got Rx,tx-still Can Not Format | zone2 | Infinity-Box | 8 | 05-26-2008 19:07 |
can not programming ffs for x100 | saeid_gsm | UST Pro II | 2 | 05-16-2007 09:08 |
