08-12-2008, 14:43 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | dual sim problem solved trend t105 second sim problem solved with new update in this phone problem was that i was unable to end the second sim call here is the log COM2 [VCP7] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: imei imei write method: mode-3 imei write channel: imei #2 for dual sim/mono-CPU new imei: 135790246811222 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: N:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080812-182806.B0E.bin flash: 01227E22022201:18E59F00000000 Backup required data Done Patch required data... 2 step(s) required to finalize Patch required data Done Special operation... Special operation Done Write... flash: 01227E22022201:18E59F00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 83 sec Remove/Install battery now ! now phone working perfectly thanks infinity for the best support |
The Following User Says Thank You to c_ahmad79 For This Useful Post: |
08-14-2008, 18:27 | #3 (permalink) |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | no with the older version it was not possible but with the special update of cm where you put second sim wite imei option that work in this phone i was unable to end the call but it really works but in my method i read flash for second cpu 6205 from working phone and after writing flash i repair imei and all ok with the perivious versions this was not possible thanks |
E61 SIM Problem Solved 100% OK! | yogesh06 | Nokia Hardware & Hardware Repair | 19 | 05-10-2011 00:47 |
anycool t828i dual sim problem? | saidgoren | Infinity-Box | 3 | 08-06-2008 00:30 |
B889 dual sim problem | oh1jty | Chinese Cocktail | 9 | 02-29-2008 18:17 |
Chines N95 Insert Sim Problem Solved | ashok_kumar459 | Various | 0 | 09-06-2007 18:40 |
Panasonic GD87 Dual Sim problem | saznat | Panasonic | 0 | 10-26-2004 23:10 |
