11-22-2014, 16:43 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Android
Member: 1916900 Status: Offline Sonork: .::NIGAM::. Thanks Meter: 81 | Dzirt pls fix thi bug see log Operation : Format File System [ v1.00 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0018 0000 [0] Flash VEN : GigaDevice , GD25LQ128 [0] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Error while prepare! Format error, something went wrong Reconnect Power/Cable! formet 99% and show this error its working phone i was just checking and also formet done phone working well fix this bug |
11-23-2014, 16:15 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. For that cases we have special repair options - tick "FFS" in repair tab and make repair. It will fix it. Repair option can FULLY Rebuild/Repair all SPD65xx phones (6500/6530/6531) with SW-related problems. Even after "great" chinese tools, which kill them hundreds. |
The Following User Says Thank You to Dzirt For This Useful Post: |
