08-23-2008, 18:13 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 775560 Status: Offline Thanks Meter: 58 | e touch 1133i can suport by infinty box ! here the log from pinfinder and from the software COM5 [VCP1] selected Device: Beyond-B555 Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL P Y 0 A Z 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sta_20080822-185956.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sec_20080822-190043.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-complete_20080822-190047.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Program Files\InfinityBox\Pana01\e touch 1133i_flash_20080822-190147.B1X completed Finished, Remove/Install battery now ! Time used: 179 sec software version: 1.12 cable type: 1x18 (L18A) platform: PMB: Infineon e-gold searching adapter at COM5... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold (820000) result: Rx:8 Tx:4 time required: 49 sec Power On ! and this link for the readed file flash or my backup file http://rapidshare.com/files/13954325...90147.B1X.html |
The Following User Says Thank You to juwanapati For This Useful Post: |
08-23-2008, 20:11 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
08-26-2008, 04:43 | #4 (permalink) |
Member: 775560 Status: Offline Thanks Meter: 58 | @mov009 this not mtk chip i think infenion e gold chip @ps no just wanna share that this handset suport too by infinity using beyond b 555 flasher , i hope it will fully suport like beyond b555 with true name e touch 1133 i thanks |
is nokia3600s unlock suported by mt-box | kakaomar | MT-BOX | 1 | 05-09-2009 15:33 |
vk 1010 is not suported by infinty???? | fasternaiger | Infinity-Box | 9 | 03-04-2009 23:45 |
nokia 2630 can unlock by mt box | niket-shah | MT-BOX | 2 | 12-22-2007 18:11 |
lg kg275 come back to live by infinty box 2day | stivubicco | Infinity-Box | 4 | 11-14-2007 07:54 |
