01-24-2010, 12:39 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Still Dead After Complete Format here is log. COM6 [VCP0] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4703:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.07, database date: 16.01.2010): M5120_HRD_UI1_EN+FR+SP+PR+GR+GE+TU_128+32FLASH_A02 .BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: M5120_HRD_UI1_EN+FR+SP+PR+GR+GE+TU_128+32FLASH_A02 .BIN project-id: M5120_HRD_UI1_EN+FR+SP+PR+GR+GE+TU_128+32FLASH_A02 , 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC240200000000:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:18E59F00000000 Finalization Done Finished, time used: 1 min 21 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-24-2010, 14:27 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Hello Read full flash backup by ON phone then flash with read file & post here result...... before any oppration first read your dead phone backup file....... |
01-25-2010, 20:42 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try this one: flashfiles/ChineseMiracle/_MT6205-MT6227/M5120_MD_EN+AR+BO+IN+RU+VI+TH+MA_128+32FLASH_A01_1 6m_En_Ru_Ml_Id_Th_Vn_Farsi_Ar.B0M.bin |
zte gx 761 dead after complete formate | neeraj1st | Infinity-Box | 5 | 08-20-2010 16:11 |
q380 dead after complete flash still dead | bhoybits99 | PadFinder box | 1 | 12-21-2008 11:45 |
Spice S700 After complete Format FFS display is BLACK . | amol_sm | Infinity-Box | 6 | 04-21-2008 16:58 |
anycool no network after complete format ffs | sezief | Infinity-Box | 16 | 02-10-2008 13:30 |
C139.....still Dead After Complete Flashing. | albarka network | Infinity-Box | 14 | 09-11-2006 19:18 |
