Old 01-25-2010, 08:14   #1 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
E100 jin ke flashing problem stranges need help
hello team i need you help this i flash my phone in infinity the phone now was dead the history of phone is if you insert sim the phone restarting i try format ffs the phone is dead i flash the ffs gat in support the phone now is totally dead now pleas i need your help team here in all flashing detail .
COM8 [VCP0] selected
module v3.06
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001B03:0002
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000000:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: H620FIVE_PCB01_GPRS_MT6225_S00.Q8_00A_VC_00.BIN
project-id: Q8_00A_VC.00, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: H620FIVE_PCB01_GPRS_MT6225_S00.Q8_00A_VC_00__fullf lash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\E100\H620FIVE_PCB 01_GPRS_MT6225_S00.Q8_00A_VC_00__fullflash_2010012 5-140130.B0M.bin
Finished, time used: 32 min 55 sec
Remove/Install battery now !
E100 FLASHING FLASH FILE IN SUPPORT FLASHING COMPLETE BUT THE PHONE STEEL DEAD TOTALLY DEAD NEED GOOD FIRWARE AND FFS
module v3.06
Action: write flash
"smart write" active
write: Firmware
H620FIVE_PCB01_GPRS_MT6225_S00.Q8_00A_VC_00__E100_ 16m_En_Ml_Id_Th_Cn.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001B03:0002
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
reading: H620FIVE_PCB01_GPRS_MT6225_S00.Q8_00A_VC_00__ffs.. .
file saved: C:\Program Files\InfinityBox\ChineseMiracle\E100\H620FIVE_PCB 01_GPRS_MT6225_S00.Q8_00A_VC_00__ffs_20100125-144509.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Code CRC check error fix...
firmware do not have "Code CRC check error" area
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 3 min 12 sec
Old 01-25-2010, 08:16   #2 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
here in format ffs i gat backup but when i try to insert backup and flashing complete but phone now not power on pleas team help
module v3.06
Action: erase whole flash chip
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001B03:0002
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\H620FIVE_PCB01_GP RS_MT6225_S00.Q8_00A_VC_00__ffs_20100125-150938.B0E.bin
====> Write ...
Write Done
chip formatting...
Erase: chip 1 of 1
Finalization Done
Finished, time used: 4 min 41 sec
Old 01-25-2010, 20:58   #3 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
can you find same working phone on local market?
sharp 802sh flash problem . i need help Bondho Khondkar FuriouS II 6 11-29-2013 03:53
E100 jin ke mobile dual band tv flashing complete successfully okay lilong_lee Infinity-Box 0 01-25-2010 09:49
flashing problem cu720 need help mr vygis uburo22 VygisToolbox 3 08-26-2009 18:44
D720 flash problem please need help MobileserviceNL UST Pro II 7 10-10-2008 08:42
Strange problem I need help very badly. cole Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 08-17-2001 02:48
Page generated in 0.35118 seconds with 8 queries
