06-26-2009, 18:00 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
Alcatel S120 Flash File not found in support [SOLVED] | surin | PolarBox 3 | 16 | 03-30-2010 10:57 |
★.★.★.★.★ BlackBerry, HTC, Alcatel ! ALL UNLIMITED !!! ★.★.★.★.★ | MB code | Main Sales Section | 0 | 03-29-2010 12:49 |
10-02-2008 New Alcatel VLE5 language packs for E157, E157a, GE23, GE25 and GE61c! | GSMtricks | Multi-Box | 7 | 02-11-2008 11:11 |
10-02-2008 New Alcatel VLE5 language packs for E157, E157a, GE23, GE25 and GE61c! | GSMtricks | Multi-box LITE | 0 | 02-10-2008 14:24 |
Alcatel E157a | libra202 | Alcatel TCL Hardware Repair | 0 | 01-27-2006 18:42 |
