12-14-2008, 10:11 | #1 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 523957 Status: Offline Thanks Meter: 118 | e207 alcatellllllllllllllll sucsufuuuuuuuuuullllllllllllllllllllllllllllllll module v1.30 Device: Alcatel-E207 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E207_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E207_eeprom_calibration-1_20081214-100832.80E.bin Read data done Check data ... Check data done Write ... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 62 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to redouane2007 For This Useful Post: |
12-14-2008, 11:16 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
Want to buy Alcatel E207, E201. C701, C707, C820, C825 Urgent! | GSMtricks | Multi-Box | 7 | 11-09-2008 20:00 |
Info About E101 E207 E207 Alcatel locosto based | PADERF | AlcaBull | 14 | 05-09-2008 19:32 |
Alcatel E207 Unlock Help | tersace | Multi-box LITE | 3 | 03-29-2008 16:03 |
e207 unlock | Tamer_Elhosary | FuriousGold | 14 | 10-08-2007 17:30 |
