01-21-2010, 00:49 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 772508 Status: Offline Thanks Meter: 16 | e227 dead after flash hi y have a e227 dead after flashing. i flashed because after unlock and imei repair the phone shows something about mepd. the original flash of the phone was from tigo colombia y flashed with the same flash: firm + lp + eeprom all form tigo but after that the phone dont power on. how i must flash ??? E227_ffs_03_Tigo-Colombia.80E is ffs or eeprom _?? i must flash E227_ffs_03_Tigo-Colombia.80E in ffs and in eeprom or only in eeprom ?? i am sorry this is mi fisrt phone of this type. thanks a lot |
01-21-2010, 22:59 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, use the next files: E227_firmware_U7CA_128_Tigo-Colombia E227_lp_07O_905_Tigo-Colombia E227_ffs_03_Tigo-Colombia Please, flash "ffs" file as "ffs". |
01-22-2010, 19:25 | #3 (permalink) |
Member: 772508 Status: Offline Thanks Meter: 16 | COM3 [VCP0] selected module v1.38 Device: Alcatel-E227 "advanced chip detection" active Action: flash write "smart write" active write: Firmware E227_firmware_U7CA_128_Tigo-Colombia.80M.bin skip: Flex/Customization write: Language Pack E227_lp_07O_905_Tigo-Colombia.80P.bin write: FFS/File system E227_ffs_03_Tigo-Colombia.80E.bin skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E227_eeprom_calibration-1... file saved: C:\Archivos de programa\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20100122-132215.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 012A7E2A242A00:54000000000000 Write: Firmware Area: Language Pack flash: 012A7E2A242A00:54000000000000 Write: Language Pack Area: FFS/File system flash: 012A7E2A242A00:54000000000000 Write: FFS/File system Write done Finished, time used: 3 min 13 sec Remove/Install battery now ! hi the phone still dead |
02-01-2010, 12:25 | #4 (permalink) |
Junior Member Join Date: Feb 2006
Member: 229875 Status: Offline Thanks Meter: 0 | I have the same problems. Phone flashing ok, but not powered on. Can you help me to deside this problem? COM8 [ProlificSerial2] selected module v1.38 Device: Alcatel-E227 "advanced chip detection" active Action: flash write "smart write" active write: Firmware E227_firmware_U7CC_145.80M.bin skip: Flex/Customization write: Language Pack E227_lp_13O_905_En_De_Ru_Bg_Ua.80P.bin write: FFS/File system E227_ffs_05.80E.bin skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E227_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20100201-124428.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 012A7E2A242A00:54000000000000 Write: Firmware Area: Language Pack flash: 012A7E2A242A00:54000000000000 Write: Language Pack Area: FFS/File system flash: 012A7E2A242A00:54000000000000 Write: FFS/File system Write done Finished, time used: 1 min 17 sec Remove/Install battery now ! |
alcatel e227 dead after writing firmare | vladic100 | Infinity-Box | 10 | 05-31-2010 16:09 |
6300 dead after flash 6233 dead after flash | mobileZONE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-27-2010 01:17 |
Dead 9210e Orange UK Dead after flashing :( | PhantomGSM | Trisha & Matrix Flasher | 4 | 05-06-2009 12:02 |
e227 dead after unlock | klodi | Infinity-Box | 5 | 03-03-2009 15:58 |
