07-29-2018, 10:48 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | e4 mt6261 need flash file Card found : S/N : 53471D69 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 23 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C6125A62575B4859BC2C63875DE24797 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : WH61D_T16_A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13 _52_MP_V2_F21.bin FileVersion : MAUI.11C.W13.52.MP.V2.F21 Done! Elapsed: 00:00:06 Reconnect Power/Cable! |
07-29-2018, 18:26 | #3 (permalink) |
Member: 383211 Status: Offline Thanks Meter: 131 | mobile show invalid sim.i repaired imei but signal not ok.i repaired same problem with flashed full firmware.i needed this firmware.i also read its orignol file.but cm2 show bad file Last edited by pakmobiles; 07-29-2018 at 18:34. |
07-30-2018, 07:04 | #6 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Try....And Post Result Here FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F27 https://mega.nz/#!geZ32CoQ!a-J1d2lBY...5314Qz1VK5y75Y |
07-30-2018, 10:26 | #7 (permalink) | |
Member: 383211 Status: Offline Thanks Meter: 131 | Quote:
FileVersion : MAUI.11C.W13.52.MP.V2.F21 " Card found : S/N : 53471D69 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C6125A62575B4859BC2C63875DE24797 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V 0770.bin FileVersion : 1307QM_0202_V0770 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Load File File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F27.bin FileVersion : MAUI.11C.W13.52.MP.V2.F27 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F27--Ok-.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C6125A62575B4859BC2C63875DE24797 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F27.bin FileVersion : MAUI.11C.W13.52.MP.V2.F27 Flash now Erase region , wait ... Write data , wait ... Write : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F27--Ok-.bin Done! Elapsed: 00:00:48 Reconnect Power/Cable! Last edited by pakmobiles; 07-30-2018 at 10:34. | |
10-23-2018, 21:05 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
