05-08-2016, 19:52 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | INFINITY CM2 NOT SUPPORT E455 FULLY U CAN TRY FOR THE DUMP TO FLASH OR WAIT FOR MR.Jaydi FOR MORE INFO WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
05-08-2016, 21:50 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 16
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | its E445 Code: ======= Flash Files set for flashing : [ MCU ] : MT6575__LGE__LG-E445__vee4ds_open_esa__vee4ds__ALPS.JB.TC1.SP.V13__Android_4.1.2.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 114 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x00 , OEM : 0000 [eMMC] : FLASH_INF : [NOT_IN_BASE] , [eMMC] : FLASH_CID : 00000000000000000000000000000000 [eMMC] : FLASH_BRT : 0x00000000 , 0x00000000 , 0x00000000 [eMMC] : FLASH_LEN : 0x0000000000000000 [eMMC] : FLASH_UCP : 0 MiB [eMMC BAD_CONN] DEV RID : 1F4EF5D1A8BAB6E904B8A1016D6EE80A INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Skip HSUSB init Brand : lge ProdName : vee4ds_open_esa ProdModel : LG-E445 Device : vee4ds AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.TC1.SP.V13 ISPFF ID : 6575 , TARGET ID : 6575 FlashFile is differs from eMMC settings, continue by user request DRAM not initialized , will try init now DRAM init failed! Flash pre-erase enabled Erase Flash now ... Flash pre-erase failed :( Write Flash now ... [ MCU ] : MT6575__LGE__LG-E445__vee4ds_open_esa__vee4ds__ALPS.JB.TC1.SP.V13__Android_4.1.2.ispff Init Ok , Sending blocks ... Write failed :( Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:00:35 Reconnect Power/Cable! |
05-08-2016, 22:14 | #5 (permalink) |
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | before dead Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 125 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A3E6962109 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 1F4EF5D1A8BAB6E904B8A1016D6EE80A INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : vee4ds_open_ame ProdModel : LG-E445 Device : vee4ds AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.TC1.SP.V13 MODEM : BaseBand : MT6575_S01_11AMDW1222_TC1_SP_W13_12 Done! Elapsed: 00:00:13 Reconnect Power/Cable! after write full dump dead Code: ======= Flash Files set for flashing : [ MCU ] : MT6575__LGE__LG-E445__vee4ds_open_esa__vee4ds__ALPS.JB.TC1.SP.V13__Android_4.1.2.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 125 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A3E6962109 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 1F4EF5D1A8BAB6E904B8A1016D6EE80A INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : lge ProdName : vee4ds_open_esa ProdModel : LG-E445 Device : vee4ds AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.TC1.SP.V13 ISPFF ID : 6575 , TARGET ID : 6575 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MT6575__LGE__LG-E445__vee4ds_open_esa__vee4ds__ALPS.JB.TC1.SP.V13__Android_4.1.2.ispff Init Ok , Sending blocks ... Write failed :( Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:09:59 Reconnect Power/Cable! |
