12-18-2009, 18:28 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | E699 recovered by INFINITY!!! COM6 [VCP0] selected module v3.01 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0403:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.3.01, database date: 30.11.2009): S101CM01_PCB01_GPRS_MT6225_S00.S101C_LXT_8L_V01_SP AN21K_080624.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: S101CM01_PCB01_GPRS_MT6225_S00.S101C_LXT_8L_V01_SP AN21K_080624.BIN ver. sw 2: S101C_LXT_8L_V01_SPAN21K_080624, 00000000 code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00FC0000 Detected ffs/eeprom address is non-standard: 00FC0000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00FC0000 detecting ffs/eeprom size... ffs/eeprom size: 00040000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00FC0000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: S101CM01_PCB01_GPRS_MT6225_S00.S101C_LXT_8L_V01_SP AN21K_080624__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\S101CM01_PCB01_GP RS_MT6225_S00.S101C_LXT_8L_V01_SPAN21K_080624__ffs _20091218-224252.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:18E59F00000000 Finalization Done Finished, time used: 374 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Same condition but alive.. How 2 solve hanging problem, PLZ HELP |
12-19-2009, 14:42 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! now only flashing can be tried. but unfortuantely, we dont have such firmware in our collection. can you find same working phone to read out full flash? |
how to convert other file not seen by infinity to be seen by infinity? | GOODNESS | Infinity-Box | 1 | 05-22-2009 21:48 |
<< Dead Samsung E250 recovered by NS Pro >> | zeel_zeel | NSPRO | 1 | 07-18-2008 22:28 |
sonyericsson K220i restarting successfully recovered By Infinity.. | harim_1981 | Infinity-Box | 2 | 11-11-2007 12:45 |
LG8330 Overload not recovered by USB SMART | JammerTwo | SonyEricsson (USB-Smart) | 0 | 11-11-2005 03:12 |
two k300i die recover by SONICS !!! | alifia | Sonics Box | 4 | 10-31-2005 05:07 |
