Old 08-01-2010, 11:45   #1 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
E79+ pinout
E79+ pinout by info_gsm
The Following User Says Thank You to MMDEBILI For This Useful Post:
Old 08-01-2010, 17:07   #2 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
COM3 [VCP0] selected
module v3.20
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:FF03:000B
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Old 08-02-2010, 20:25   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
can you read full flash using this pinout or also gives same error?
please hold power button pressed long enough
Old 08-03-2010, 19:22   #4 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
sorry no phone in my hand
Old 08-15-2010, 17:39   #5 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
FORMATTING CODES
*#66*# Set Factory Mode CONFIRMED
*#8375# Show Software Version CONFIRMED
*#1234# A2DP ACP Mode CONFIRMED
*#1234# A2DP INT Mode CONFIRMED
*#0000# + Send : Set Default Language CONFIRMED
*#0007# + Send : Set Language to Russian CONFIRMED
*#0033# + Send : Set Language to French CONFIRMED
*#0034# + Send : Set Language to Spanish CONFIRMED
*#0039# + Send : Set Language to Italian CONFIRMED
*#0044# + Send : Set Language to English CONFIRMED
*#0049# + Send : Set Language to German CONFIRMED
*#0066# + Send : Set Language to Thai CONFIRMED
*#0084# + Send : Set Language to Vietnamese CONFIRMED
*#0966# + Send : Set Language to Arabic CONFIRMED
More some codes for reset mobile china
*#77218114#
*#881188#
*#94267357#
*#9426*357#
*#19912006#
*#118811#
*#3646633#
CHINESE MODELS:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send
for n95 that trips off on making call use
*#3646633#
...:::| INFO_GSM |:::...
I am not responsible for any damage of ur phone u have to use it in ur own risk.
Old 12-12-2010, 00:00   #6 (permalink)
laptop.dz's Avatar
Member: 834813
Thanks Meter: 125
Post E79+ fullflash
E79+ fullflash read using pinout above
  COM2 selected
  module  v3.15
  Action: read flash
  ====>  Boot ...
  19200 fixed
  Connecting, wait...
  CPU: MT6225
  high speed boot On
  chip: 0001:DA03:0005
  status: FF
  Boot Done
  ====>  Initialize ...
  flash: EC240200000000:18E59F00000000
  flash: Samsung K5L2833ATA T 16Mb
  otp offset: 00FF0000
  detecting chip #01 in region #00...
  detecting chip #02 in region #00...
  detecting chip #03 in region #00...
  number of flash chip/regions detected: 04/01
  Initialize Done
  ====>  Set baud ...
  460800
  Set baud Done
  ====>  Initialize bootcode ...
  Initialize bootcode Done
  ====>  Check firmware integrity ...
  device parameters detection in progress...
  it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
  total flash region size: 01000000
  usb bootloader detect...
  usb bootloader detect (phase #2)...
  usb bootloader (chip) is absent
  searching rom info...
  search rom info finished
  rom info structure: 2nd [standard] generation
  TCL-ID is absent
  rom info detection finished
  New firmware detected (v.3.15, database date: 06.06.2010):
  BB35_MULTI_PCB01_GPRS_MT6225_S00.BB35_HD_L10EN_314_100109_LCD_CAM_K5L2833_75_CTF_FM.BIN
  This firmware is missing in support area. If this phone is good and working:
  - download latest software from support area and try again, probably this firmware already supported in latest software
  - make "Read full flash" operation
  - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
  - include in your e-mail full text from phone back label (phone name etc.)
  rom info ver: 04
  sw version: BB35_MULTI_PCB01_GPRS_MT6225_S00.BB35_HD_L10EN_314_100109_LCD_CAM_K5L2833_75_CTF_FM.BIN
  project-id: BB35_HD_L10EN_314_100109_LCD_CAM_K5L2833_75_CTF_FM, 00000000
  code offset: 00000000
  ffs offset/size [01]: 00E00000/00200000
  TCL-ID is absent
  detecting ffs/eeprom area in 1 chip(s)...
  standard ffs/eeprom offset detected: 00E00000
  standard ffs/eeprom offset confirmed: 00E00000
  detecting ffs/eeprom size...
  ffs/eeprom size: 00200000
  ffs/eeprom chip: 00
  ffs/eeprom area: 00000000:00E00000-00FFFFFF
  sec info (detailed) detection...
  searching sec info#1...
  search sec info#1 finished
  Check firmware integrity Done
  ====>  Check firmware content ...
  Check firmware content Done
  ====>  Backup required data ...
  reading: BB35_MULTI_PCB01_GPRS_MT6225_S00.BB35_HD_L10EN_314_100109_LCD_CAM_K5L2833_75_CTF_FM__fullflash...
  file saved: E:\Program Files\InfinityBox\ChineseMiracle\nokia\BB35_MULTI_PCB01_GPRS_MT6225_S00.BB35_HD_L10EN_314_100109_LCD_CAM_K5L2833_75_CTF_FM__fullflash_20101211-124033.B0M.bin
  Finished, time used: 17 min 18 sec
  Remove/Install battery now !
8810 pinout?? timitiz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-11-2012 11:10
Please Help, Pinout of N8810 mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-30-2010 15:53
8810 pinouts for dejan flasher !?!?!? makona Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-03-2001 04:39
8850 pinouts MDR Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 12-30-2000 01:23
Page generated in 0.19472 seconds with 11 queries
