Old 03-14-2010, 14:50   #1 (permalink)
Member: 62866
Thanks Meter: 49
OT-305x unlock problem
=== [14.3.2010 a. 14:12:17] ====
COM4 [VCP0] selected
module v3.25
Device: Alcatel-305X
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:AC5E:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.45071 A81.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_2FA8B35C].rpl
rom info detection finished
New firmware detected (v.3.25, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 45071A81
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN
project-id: MAUI.08A.W08.36.SP1.V34, 5CB3A82F
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID is absent
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, part #2) calculation...
identification header detected
customization: XP16CF13
error: customization name is unknown
Can not calculate required data !
Find original simfree model, read full flash and send to support
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
use default security area (sec info, part #1) pattern
max address is too big, should be recalculated: 08BF8000->08667144
..................security area (sec info, part #1) detecting size...
error: security area (sec info, part #1) size is incorrect: 01C0 instead of 0374
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X__system_log_45071A81_2FA8B35C_20100314-141618.B0X.bin
Finished, time used: 3 min 56 sec
Remove/Install battery now !
please solve this problem
br
stefan
Old 03-14-2010, 16:30   #2 (permalink)
Nadjombe's Avatar
Member: 185608
Thanks Meter: 592
Try write imei before!Use imei on back of phone.
The Following User Says Thank You to Nadjombe For This Useful Post:
Old 03-14-2010, 17:21   #3 (permalink)
Member: 62866
Thanks Meter: 49
re
module v3.25
Action: "repair imei"
new imei: 357769030816721
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
device-id: 45071A81
rom info ver: 05
TCL-ID is absent
area1 is valid
area2 is valid
area3 is valid
area4 is valid
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35776903081672
Backup required data Done
====> Patch required data ...
pass #1
firmware remap[01]: 08000000
pass #2
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write: imei
sec info (fast) detection...
error: relocation table offset is unknown
error: jump table is not found or incorrect
can't detect customization version
error: can't calculate security area (sec info, part #2), existing data will be used
Check support area for updates !
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_45071A81_2FA8B35C_20100314-181458.B0X.bin
Finished, time used: 4 min 55 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
module v3.25
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
device-id: 45071A81
rom info ver: 05
TCL-ID is absent
area1 is valid
area2 is valid
area3 is valid
area4 is valid
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X__system_log_45071A81_2FA8B35C_20100314-181903.B0X.bin
Finished, time used: 2 min 51 sec
but phone is steel locked
Old 03-14-2010, 17:39   #4 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
New software version with this version support will be released on days.
The Following User Says Thank You to YellowBoss For This Useful Post:
Alcatel ot-c550 unlock problem rubeltelecom FuriousGold 18 01-20-2013 12:03
Alcatel ot 103 Unlock probleme abote didier Infinity-Box 4 04-26-2010 17:04
Ot-c630 Unlock Problem sonitex FuriousGold 1 09-24-2007 11:01
MT-560...OT-531 unlocking problem Kashif Khan Mitsubishi 6 02-13-2006 14:52
xg1 ot 0320 unlocking problem Moosani Wray´s Products 5 12-12-2004 19:27
Page generated in 0.27084 seconds with 10 queries
