05-10-2017, 18:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | is this edl mode or not ? is this the edl mode that cmd2 nead toi flash the phone ? cause cmd2qlm don't detect the phone at all !! Card found : 1288A106 , v0135 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Code: Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! br |
05-10-2017, 18:10 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Yes tht is EDL mode but u need to Install Emergency Drivers from support how to install u can see here http://forum.gsmhosting.com/vbb/f296...video-2160627/ |
The Following User Says Thank You to princesaddam For This Useful Post: |
05-10-2017, 18:38 | #3 (permalink) | |
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
Code: Card found : xxxxxxx , v0135 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 08F78AD8 ID_BLOCK_I : 009600E1 ID_BLOCK_L : ED174D8924B2BFAA95CA0A0BD4AF2727 ID_BLOCK_L : D2A16FBEB3228C19BC7B5C959F16004B Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : STREAM ProdName : E50AE ProdModel : B3 Simply Device : HS8909QC AndroidVer: 5.1.1 Manufact. : SARL BOMARE COMPANY QLMxCPU : MSM8909 QLMxPRJ : L1211.6.03.08.DZ00 Done! Elapsed: 00:00:31 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : STREAM Device Manufact.: SARL BOMARE COMPANY Device Model : HS8909QC Device CPU : MSM8909 Device IntName : E50AE Device Version : 5.1.1 CU_SWVer : SARL BOMARE COMPANY Device Compile : 10/01/2016 04:51:11 Device Project : L1211.6.01.01.DZ00 Device ExtInfo : B3 Simply Load Ok! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 08F78AD8 ID_BLOCK_I : 009600E1 ID_BLOCK_L : ED174D8924B2BFAA95CA0A0BD4AF2727 ID_BLOCK_L : D2A16FBEB3228C19BC7B5C959F16004B Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Files in Chain : 29 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : misc.img Flashing : lsplash.img Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : userdata.img Flashing : gpt_backup0.bin Boot settings configured! Flashing done! Done! Elapsed: 00:02:57 Reconnect Power/Cable! | |
The Following User Says Thank You to .:bono:. For This Useful Post: |
