04-27-2007, 17:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Lebanon Age: 45
Member: 53113 Status: Offline Thanks Meter: 16 | EF51 error by unlocking the phone!!! I try to unlock Benq-Siemens and i get this error!!! Why!!! COM8 selected Device: BenQ EF51 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 001C:00C8001C00C8 file saved: backup_eeprom-00_20070427-180537.91F.bin Check Parameters Done Check Space... Flash: 001C:00C8001C00C8 flash: Mitsubishi B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 001C:00C8001C00C8 Err: error flash vpp Err: error flash vpp try#1 to recover write error at 01600000 Err: flash end try#2 to recover write error at 01600000 Err: answer#EE try#3 to recover write error at 01600000 Err: answer#66 try#4 to recover write error at 01600000 Err: answer#13 try#5 to recover write error at 01600000 Err: answer#E0 try#6 to recover write error at 01600000 Err: answer#00 try#1 to recover write error at 01602000 Err: answer#00 try#2 to recover write error at 01602000 Err: answer#E0 try#3 to recover write error at 01602000 Err: answer#00 try#4 to recover write error at 01602000 Err: answer#00 try#5 to recover write error at 01602000 Err: answer#E0 try#6 to recover write error at 01602000 Err: answer#00 try#1 to recover write error at 01604000 Err: answer#00 try#2 to recover write error at 01604000 Err: answer#00 try#3 to recover write error at 01604000 Err: answer#FF try#4 to recover write error at 01604000 Err: answer#00 try#5 to recover write error at 01604000 Err: answer#00 try#6 to recover write error at 01604000 Err: answer#00 try#1 to recover write error at 01606000 Err: answer#00 try#2 to recover write error at 01606000 Err: answer#00 try#3 to recover write error at 01606000 Err: answer#00 try#4 to recover write error at 01606000 Err: answer#00 try#5 to recover write error at 01606000 Err: answer#00 try#6 to recover write error at 01606000 Err: answer#00 try#1 to recover write error at 01608000 Err: answer#00 try#2 to recover write error at 01608000 Err: answer#00 try#3 to recover write error at 01608000 Err: answer#00 try#4 to recover write error at 01608000 Err: answer#07 try#5 to recover write error at 01608000 Err: answer#00 try#6 to recover write error at 01608000 Err: answer#E0 try#1 to recover write error at 0160A000 Err: answer#00 try#2 to recover write error at 0160A000 Err: answer#00 try#3 to recover write error at 0160A000 Err: answer#00 try#4 to recover write error at 0160A000 Err: answer#F0 try#5 to recover write error at 0160A000 Err: answer#00 try#6 to recover write error at 0160A000 Err: answer#00 try#1 to recover write error at 0160C000 Err: answer#F8 try#2 to recover write error at 0160C000 Err: answer#00 try#3 to recover write error at 0160C000 Err: answer#00 try#4 to recover write error at 0160C000 Err: answer#F0 try#5 to recover write error at 0160C000 Err: answer#00 try#6 to recover write error at 0160C000 Err: answer#00 try#1 to recover write error at 0160E000 Err: answer#F0 try#2 to recover write error at 0160E000 Err: answer#00 try#3 to recover write error at 0160E000 Err: answer#00 try#4 to recover write error at 0160E000 Err: answer#00 try#5 to recover write error at 0160E000 Err: answer#F8 try#6 to recover write error at 0160E000 Writing Fail Finished, time used: 93 sec Remove/Install battery now ! |
04-27-2007, 19:53 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | It seems it is cable problem. Phone still connects? If does, try to connect it with lover speed , and try it again.... (with full battery) Last edited by huzsolt; 04-27-2007 at 20:05. |
04-29-2007, 18:12 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: SLOVENIA, LJUBLJANA Age: 55
Member: 48933 Status: Offline Thanks Meter: 104 | read this http://forum.gsmhosting.com/vbb/show...ht=EF51+unlock http://forum.gsmhosting.com/vbb/show...ht=EF51+unlock http://forum.gsmhosting.com/vbb/show...ht=EF51+unlock i thik there is no solution to unlock EF51 at the time? br,a |
04-29-2007, 18:23 | #4 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
we are steel working about EF51 we need this phone in our hand to make search | |
E75 unlock error at the finish but Succes Unlock The phone | ServiceTEL | Universalbox | 0 | 05-12-2009 17:37 |
EF51 ERROR in UNLOCKING... | geo_izak | Infinity-Box | 4 | 02-23-2009 17:57 |
by gro the phone ku580 not suported :::ANSWERED::: | redouane2007 | PolarBox 3 | 2 | 12-25-2008 17:23 |
error in reseting the phone lock code of c902 in ub | vinay_sharma | Universalbox | 5 | 09-16-2008 13:00 |
A New User Doubt About K800i Gdfs Error During Complete The Phone--help | zonetrichur | Cruiser Suite | 8 | 06-07-2007 11:03 |
