01-24-2007, 20:36 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 53
Member: 50212 Status: Offline Thanks Meter: 0 | EF51 finally unlocked COM1 selected Device: BenQ EF51 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 001C:00C8001C00C8 file saved: Backup_eeprom-00_2007-1-24_12-50-13.91F.bin Check Parameters Done Check Space... Flash: 001C:00C8001C00C8 flash: Mitsubishi B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 001C:00C8001C00C8 map: B Err: error flash vpp Err: error flash vpp try#1 to recover write error at 01770000 Err: flash end try#2 to recover write error at 01770000 Err: error flash vpp try#3 to recover write error at 01770000 Err: flash end try#4 to recover write error at 01770000 Err: error flash vpp try#5 to recover write error at 01770000 Err: flash end try#6 to recover write error at 01770000 Err: answer#00 try#1 to recover write error at 01772000 Err: answer#00 try#2 to recover write error at 01772000 Err: answer#00 try#3 to recover write error at 01772000 Err: answer#00 try#4 to recover write error at 01772000 Err: answer#00 try#5 to recover write error at 01772000 Err: answer#00 try#6 to recover write error at 01772000 Err: answer#00 try#1 to recover write error at 01774000 Err: answer#00 try#2 to recover write error at 01774000 Err: answer#00 try#3 to recover write error at 01774000 Err: answer#00 try#4 to recover write error at 01774000 Err: answer#00 try#5 to recover write error at 01774000 Err: answer#00 try#6 to recover write error at 01774000 Err: answer#00 try#1 to recover write error at 01776000 Err: answer#00 try#2 to recover write error at 01776000 Err: answer#00 try#3 to recover write error at 01776000 Err: answer#00 try#4 to recover write error at 01776000 Err: answer#00 try#5 to recover write error at 01776000 Err: answer#00 try#6 to recover write error at 01776000 Err: answer#00 try#1 to recover write error at 01778000 Err: answer#00 try#2 to recover write error at 01778000 Err: answer#00 try#3 to recover write error at 01778000 Err: answer#00 try#4 to recover write error at 01778000 Err: answer#00 try#5 to recover write error at 01778000 Err: answer#00 try#6 to recover write error at 01778000 Err: answer#00 try#1 to recover write error at 0177A000 Err: answer#00 try#2 to recover write error at 0177A000 Err: answer#00 try#3 to recover write error at 0177A000 Err: answer#00 try#4 to recover write error at 0177A000 Err: answer#00 try#5 to recover write error at 0177A000 Err: answer#00 try#6 to recover write error at 0177A000 Err: answer#00 try#1 to recover write error at 0177C000 Err: answer#00 try#2 to recover write error at 0177C000 Err: answer#00 try#3 to recover write error at 0177C000 Err: answer#00 try#4 to recover write error at 0177C000 Err: answer#00 try#5 to recover write error at 0177C000 Err: answer#00 try#6 to recover write error at 0177C000 Err: answer#00 try#1 to recover write error at 0177E000 Err: answer#00 try#2 to recover write error at 0177E000 Err: answer#00 try#3 to recover write error at 0177E000 Err: answer#00 try#4 to recover write error at 0177E000 Err: answer#00 try#5 to recover write error at 0177E000 Err: answer#00 try#6 to recover write error at 0177E000 Writing Fail Finished, time used: 449 sec Remove/Install battery now ! but phone is now unlocked thx infinity team |
:: F480v Freeze (no unlockable versions) Final Unlock method 100% :: | BouRRi_GSM | Easy-Unlocker | 2 | 11-27-2008 00:11 |
BenQ-siemens EL71 success unlocking by dreambox | jakoy | DreamBox | 0 | 07-14-2008 12:29 |
ALL-UNLOCK and PHONEXTREME ARE PROUD TO PRESENT U900 FINAL UNLOCK | kller | LG | 180 | 09-01-2007 14:39 |
problem to open EL71 FOR UNLOCK HOW | a2b2t | S-Gold Based Phones | 1 | 11-18-2006 13:48 |
nec338 FINALLY UNLOCKED !!!!!!~ | ziko | FuriouS II | 3 | 02-24-2005 14:26 |
